Hey all. New to the Robo and 3D Hubs. I got my R1+ today and have been trying to print marvin, but all of the underneath parts look all rough and “melty”. I tried lowering my extruder temp from 210 to 200 (as suggested in the marvin PDF), but it still looks the same.
Better cooling will definitely help so you could print out a fan holder to assist the filament with cooling. You could lower the temp a bit more so that it hardens sooner, try 185-190C. I believe you should be able to print with those low temps as long as it doesn’t get cooled down past 180C, at which the printer will stop printing to prevent jams. I have a Robo R1 and I use a fan from thingiverse.
I just tried at 195 and almost no filament came out, so I canceled the print. Thought I’d try a different filament, but when I attempted my (first) unload, the filament seems to be stuck… sigh.
Use fans on, maybe increase your “minimum time per layer”. If you have a heated bed, make sure it’s turned down (60c gets too hot… I keep mine @40C for PLA).
Try different filament – each color seems to have it’s own sweet spot. I’ve had issues with MicroCenter Grey and Silver filaments (no matter what temp, you can get a few layers, but then it jams), but the rest seem to work ok.
When removing filament, I usually go to “Preheat PLA”, and it can be pulled cleanly out at ~100-120C, without leaving remnants in the chamber.
Try printing a “tower” next to the Marvin. By tower I mean just a cylinder a little taller than the Marvin, this moves the hot end away from the print for a few seconds so the print cools, see if this helps good luck
I use repetier and heat up the nozzle, run it 10mm foward (extruding) and then in reverse. I pull it when its in reverse and it comes right out. No use of the lever.
Looks like my extruder is clogged… just talked to tech support and they had me try a few things but the filament is not budging. Not sure what to do next, but I sent them some pictures of the inside of the latch. Bunch of ground up filament in there.
So the right fix depends on the type of clog. If its low end (near the extruder) you can try heating the hot end and using the atomic method. If its on the high end then I recommend taking it out and cooking the hotend in the oven. 500F for about 15 mins does the trick. Then take something and push the clog out. I normally use a long 1.5 mm Allen wrench from lowes or home depot.
Basically I’ve got a piece of filament about 3" long that when pushed down is below the level that the gears can push it, and when pulled up won’t come out the last bit. I’m basically at a loss as to how to remove it. Exchanging calls with Robo tech support but it’s slow going.
You need to make sure you turn the heated bed off (set the temperature to zero). That’s what eventually did it for me.This should also be listed in the marvin instructions, at least it was when I printed it.
As for removing the clog. Remove the hot end from the Xaxis Carriage. Turn on the extruder. Once it gets hot Use one wrench/pliers to hold the heater block without crushing the heater cartridge and thermistor and another to remove the extruder tip. Do not apply any torque to the threaded rod coming out of the hot block It will break off.
Once the tip is off see if you can hold the top of the cold end of the extruder with pliers and use another pair to push the filament through the now open hot end. If it comes out reinstall the nozzle and try pushing some filament through to get some flow out of the hot end. If you are getting flow.
Pull the filament back out and reassemble you should be good to go.
If you do not get any flow then push a piece of guitar string in the nozzle until it comes out the cold end of the hot end and pull it on through the assembly. Re test flow.
If you cannot get the wire to feed in or (you have no wire small enough to push in the nozzle) remove the nozzle and heat it with a torch and burn out any plastic. When its clear you will be able to see light through the nozzle hole. Re assemble and retest flow.
If you cannot push the plug out you will need to loosen the locking nut on the threaded rod. Again hold the hot block with one wrench/set of pliers and use another to loosen the nut once its free you can unscrew the threaded rod from the hot block and remove the PTFE liner where the clog is most likely wedged. Now without the support of the threaded rod the PTFE tube is in the PTFE will flex enough to push the plug out. If the PTFE tube is badly distorted or damaged you should replace it.
Put the PTFE tube in the threaded rod.
Screw the threaded rod back into the heater block.
Snug down the locking nut. Do not over torque the nut. The threaded rod will break, mine did the first time I did this.
Re install the extruder nozzle.
Re install the extruder assembly in the carriage.
This can be done with a cold extruder however once it heats up you will need to tighten things or else it will leak.
If you do It with a hot extruder be careful the extruder is very hot use only pliers or wrenches to touch any part of it.
Remember once a part is taken off it takes a while to cool back down.
I kept killing the PTFE tube trying to print ABS (it does work, but it has to go from heating->printing->cooling without delay and my bed was taking its sweet time heating, so heat made it up from the nozzle to the PTFE tube and…), so now I replaced it. You can probably prevent failures by adding a cooling fan like for the all-metal hotends.
E3D - Good, but I got one of the ones from a bad batch. And it’s not fast to get them…
B3 Pico Innovations - Great… but the tube is thin and I snapped it off inadvertently. Also kinda long.
Hexagon - Great and pretty durable. I put the thermistor in and bend it upwards before sliding the silicone boot on so it won’t fall out.
The E3Dv6 has a Teflon tube to make it easier to use with flex (and since the PTFE is in the “actively cooled” part of the hotend, it won’t fail like the Robo3D version), but I’ve found a great pair of solutions for that:
1. Bore out the throat and put a PTFE tube from the hobbed bolt down to the top of the hotend.
2. When the hotend is clear (I made the Nylon Cold Pull thing on Thingiverse… works very well), spray some WS2 or HBN lube down it, insert a cold filament and spin it around. Do that 3 times, and the inside of the hotend will be noticeably slicker (before lube, it takes pliers to do the cold-pull. Afterwards, you can do it by hand – still a tug, but by hand).
The other thing that was problematic with my original Robo3D was the hobbed bolt… mine came in a way that kept filling itself with plastic and would stop extruding (consistently) after 4 hours (grr)… replaced with one from eBay.
It sounds like you might have pulled molten plastic into the upper portion of your extruder when you tried to pull it out. This might have caused the plastic to cool down inside the plastic portion on your extruder. If this is the case you might have to take it apart and drill it out “carefully!” This happened to me once, so now I pull it out slowly at the plastics lower transition temperature so that it doesn’t solidify inside the upper extruder. All I did was pull the cover off and removed the idler arm and drilled it out. Then I took a round tapered file and smoothed it out. Adding an oiler to your filament feed will help prevent this from happening again, or what I do is just occasionally wide some virgin olive oil onto the filament once in a while when I am extruding a lot of plastic to clean out the hot end during a change over. Hope this helps and good luck!
I did my Skype session with them yesterday and we manage to clear it by removing the hot end, heating it up, cutting the stuck filament flush with the top of the hot-end, then pushing it through the bottom using the small wrench.
Interestingly though, after my successful test print that followed, while the extruder was hot I tried to remove the filament so that I could change it and it won’t come out. Doesn’t move AT ALL when I tug on it.
So, while I’ve cleared my clog, I seem to be unable to remove filament, and that worries me…
No, your not doing it right! Take one hand and put your middle and index fingers on the spring screws, while with your thumb pulling back on the arm. Then you are releasing the pressure allowing you to use your other hand to pull the filament slowly up and out, so as to not pull molten plastic out with it!
