Mar 2016
I got am email with your comment, but now here there’s just a “.” - did you delete it on purpose or was that a mistake?
You need to make sure you turn the heated bed off (set the temperature to zero). That’s what eventually did it for me.This should also be listed in the marvin instructions, at least it was when I printed it.
As for removing the clog. Remove the hot end from the Xaxis Carriage. Turn on the extruder. Once it gets hot Use one wrench/pliers to hold the heater block without crushing the heater cartridge and thermistor and another to remove the extruder tip. Do not apply any torque to the threaded rod coming out of the hot block It will break off.
Once the tip is off see if you can hold the top of the cold end of the extruder with pliers and use another pair to push the filament through the now open hot end. If it comes out reinstall the nozzle and try pushing some filament through to get some flow out of the hot end. If you are getting flow.
Pull the filament back out and reassemble you should be good to go.
If you do not get any flow then push a piece of guitar string in the nozzle until it comes out the cold end of the hot end and pull it on through the assembly. Re test flow.
If you cannot get the wire to feed in or (you have no wire small enough to push in the nozzle) remove the nozzle and heat it with a torch and burn out any plastic. When its clear you will be able to see light through the nozzle hole. Re assemble and retest flow.
If you cannot push the plug out you will need to loosen the locking nut on the threaded rod. Again hold the hot block with one wrench/set of pliers and use another to loosen the nut once its free you can unscrew the threaded rod from the hot block and remove the PTFE liner where the clog is most likely wedged. Now without the support of the threaded rod the PTFE tube is in the PTFE will flex enough to push the plug out. If the PTFE tube is badly distorted or damaged you should replace it.
Put the PTFE tube in the threaded rod.
Screw the threaded rod back into the heater block.
Snug down the locking nut. Do not over torque the nut. The threaded rod will break, mine did the first time I did this.
Re install the extruder nozzle.
Re install the extruder assembly in the carriage.
This can be done with a cold extruder however once it heats up you will need to tighten things or else it will leak.
If you do It with a hot extruder be careful the extruder is very hot use only pliers or wrenches to touch any part of it.
Remember once a part is taken off it takes a while to cool back down.
Many thanks for the detailed write up! I actually scheduled a tier-2 Skype session for Monday to (hopefully) walk me through all this live. I’m a bit uncomfortable taking all this stuff apart when I’ve only had the printer for a few days.
I kept killing the PTFE tube trying to print ABS (it does work, but it has to go from heating->printing->cooling without delay and my bed was taking its sweet time heating, so heat made it up from the nozzle to the PTFE tube and…), so now I replaced it. You can probably prevent failures by adding a cooling fan like for the all-metal hotends.
E3D - Good, but I got one of the ones from a bad batch. And it’s not fast to get them…
B3 Pico Innovations - Great… but the tube is thin and I snapped it off inadvertently. Also kinda long.
Hexagon - Great and pretty durable. I put the thermistor in and bend it upwards before sliding the silicone boot on so it won’t fall out.
The E3Dv6 has a Teflon tube to make it easier to use with flex (and since the PTFE is in the “actively cooled” part of the hotend, it won’t fail like the Robo3D version), but I’ve found a great pair of solutions for that:
1. Bore out the throat and put a PTFE tube from the hobbed bolt down to the top of the hotend.
2. When the hotend is clear (I made the Nylon Cold Pull thing on Thingiverse… works very well), spray some WS2 or HBN lube down it, insert a cold filament and spin it around. Do that 3 times, and the inside of the hotend will be noticeably slicker (before lube, it takes pliers to do the cold-pull. Afterwards, you can do it by hand – still a tug, but by hand).
The other thing that was problematic with my original Robo3D was the hobbed bolt… mine came in a way that kept filling itself with plastic and would stop extruding (consistently) after 4 hours (grr)… replaced with one from eBay.
Thanks much for all that info. A lot to digest but I will keep it all in mind (and this page bookmarked).
I’m not sure what the idler arm means, but I’m not doing anything but pulling up on the filament (per Robo3D’s instructions).
The idler arm is the spring loaded arm that applies pressure to the filament against the hobble bolt that drives it into the extruder.
Ah, okay. No, I’m not using that trying to remove, only when I load. Is that the correct method?
To remove I’m just heating the extruder to print temp, then tugging straight up on the filament. It doesn’t move at all.
Is it possible the screws are too tight on the idler arm?
Sigh.
Any thoughts appreciated!
  1. Pull up the filament as far as it goes
  2. Cool the hotend (just to make it easy for the next bits)
  3. Remove the hotend.
  4. Push the filament down and clip the ball off it so you can remove it.
  5. Reinstall the hotend.
Mine has the quick release, though, unless you’re referring to something else?
It’s brand new, the R1+. They say on the website that it can handle just about anything. Safe to try?
Try this: Robo 3D R1 Double 40 mm fan setup - hexagon hot end by 3DNG - Thingiverse
Designed it myself.
Try this settings for your marvin print:
Prep bed with Aqua net hairspray
Nozzle: 200°C
Heatbed: 55°C
Speed: 40 mm/s
No supports
Check that your Z offset is adecuate.
After printing the double fan mount check air volume, set fans to 75% first.
Edit your firmware, change overal acceleration to 300-500
Hope this helps!
Sergio R.
