Basically I’ve got a piece of filament about 3" long that when pushed down is below the level that the gears can push it, and when pulled up won’t come out the last bit. I’m basically at a loss as to how to remove it. Exchanging calls with Robo tech support but it’s slow going.
You need to make sure you turn the heated bed off (set the temperature to zero). That’s what eventually did it for me.This should also be listed in the marvin instructions, at least it was when I printed it.
Pull up the filament as far as it goes
Cool the hotend (just to make it easy for the next bits)
Remove the hotend.
Push the filament down and clip the ball off it so you can remove it.
Reinstall the hotend.
