Mar 2016
So the right fix depends on the type of clog. If its low end (near the extruder) you can try heating the hot end and using the atomic method. If its on the high end then I recommend taking it out and cooking the hotend in the oven. 500F for about 15 mins does the trick. Then take something and push the clog out. I normally use a long 1.5 mm Allen wrench from lowes or home depot.
How to tell which?
Basically I’ve got a piece of filament about 3" long that when pushed down is below the level that the gears can push it, and when pulled up won’t come out the last bit. I’m basically at a loss as to how to remove it. Exchanging calls with Robo tech support but it’s slow going.
I’m not sure what the idler arm means, but I’m not doing anything but pulling up on the filament (per Robo3D’s instructions).
The idler arm is the spring loaded arm that applies pressure to the filament against the hobble bolt that drives it into the extruder.
Ah, okay. No, I’m not using that trying to remove, only when I load. Is that the correct method?
To remove I’m just heating the extruder to print temp, then tugging straight up on the filament. It doesn’t move at all.
Is it possible the screws are too tight on the idler arm?
Sigh.
Any thoughts appreciated!
  1. Pull up the filament as far as it goes
  2. Cool the hotend (just to make it easy for the next bits)
  3. Remove the hotend.
  4. Push the filament down and clip the ball off it so you can remove it.
  5. Reinstall the hotend.
Mine has the quick release, though, unless you’re referring to something else?
It’s brand new, the R1+. They say on the website that it can handle just about anything. Safe to try?
Try this: Robo 3D R1 Double 40 mm fan setup - hexagon hot end by 3DNG - Thingiverse
Designed it myself.
Try this settings for your marvin print:
Prep bed with Aqua net hairspray
Nozzle: 200°C
Heatbed: 55°C
Speed: 40 mm/s
No supports
Check that your Z offset is adecuate.
After printing the double fan mount check air volume, set fans to 75% first.
Edit your firmware, change overal acceleration to 300-500
Hope this helps!
Sergio R.
Nevermind… looks like they made an upgrade! Now to print one for my KS Robo3D…
