Mar 2016
Sigh.
Any thoughts appreciated!
  1. Pull up the filament as far as it goes
  2. Cool the hotend (just to make it easy for the next bits)
  3. Remove the hotend.
  4. Push the filament down and clip the ball off it so you can remove it.
  5. Reinstall the hotend.
Mine has the quick release, though, unless you’re referring to something else?
It’s brand new, the R1+. They say on the website that it can handle just about anything. Safe to try?
Try this: Robo 3D R1 Double 40 mm fan setup - hexagon hot end by 3DNG - Thingiverse
Designed it myself.
Try this settings for your marvin print:
Prep bed with Aqua net hairspray
Nozzle: 200°C
Heatbed: 55°C
Speed: 40 mm/s
No supports
Check that your Z offset is adecuate.
After printing the double fan mount check air volume, set fans to 75% first.
Edit your firmware, change overal acceleration to 300-500
Hope this helps!
Sergio R.
Nevermind… looks like they made an upgrade! Now to print one for my KS Robo3D…
