I use repetier and heat up the nozzle, run it 10mm foward (extruding) and then in reverse. I pull it when its in reverse and it comes right out. No use of the lever.
Do you have a picture of your marvin?
Q: Do I need a different tube in order to print with PETG? The tech on the phone yesterday said something about that…
Are you releasing the idler arm by pulling it back while pulling up on the filament?
I’m not sure what the idler arm means, but I’m not doing anything but pulling up on the filament (per Robo3D’s instructions).
The idler arm is the spring loaded arm that applies pressure to the filament against the hobble bolt that drives it into the extruder.
Ah, okay. No, I’m not using that trying to remove, only when I load. Is that the correct method?
To remove I’m just heating the extruder to print temp, then tugging straight up on the filament. It doesn’t move at all.
Is it possible the screws are too tight on the idler arm?
Sigh.
Any thoughts appreciated!
What would the remedy be?
Pull up the filament as far as it goes
Cool the hotend (just to make it easy for the next bits)
Remove the hotend.
Push the filament down and clip the ball off it so you can remove it.
Reinstall the hotend.
Mine has the quick release, though, unless you’re referring to something else?
It’s brand new, the R1+. They say on the website that it can handle just about anything. Safe to try?
Try this: Robo 3D R1 Double 40 mm fan setup - hexagon hot end by 3DNG - Thingiverse
Designed it myself.
Try this settings for your marvin print:
Prep bed with Aqua net hairspray
Nozzle: 200°C
Heatbed: 55°C
Speed: 40 mm/s
No supports
Check that your Z offset is adecuate.
After printing the double fan mount check air volume, set fans to 75% first.
Edit your firmware, change overal acceleration to 300-500
Hope this helps!
Sergio R.
Love the file! I have looking for one!
This worked great, thanks for the tip!
