Updating the firmware is definitely something I will do to control speed. I have seen guides on how to do this, but doesnt look that easy. So will do the straightforward things to start. Inevitably i’m sure i’ll end up updating the firmware to the SailFish.
I’ll also do as you say and add a fan. Ive seen a few different types of fans, it seems some people put perspex sides on the box and a big fan on the side, and some add another fan near the extruder head. this sounds a bit tricky but as i get more prints under my belt i’ll probably do this mod as well!
Apart from all the good adivse you have gotten, to improve maker-ware download prof-tweak from nothing lab. It provides substantially more tuneability, its free. I used it for about 4 month, got comfortable with the printer and was getting very good prints until i wanted the versatilty of s3d for its support. In thingiverse i put a ctc nozzle calibration which really helped me tweak my nozzle with proftweak. Good luck
Okay - So here is attempt 6 results with the following parameters:
Attempt 06
filename: pilot06
Extruder: 190 c
Printer Bed: 50 c - With Wickes Heavy duty masking tape (interior and exterior)
Speed while travelling: 100mm/s
Extruding speed: 40mm/s.
Room temp: 15.3 C.
It all seemed to be going well, It adhered to the tape very well. the Top of the hat came out much better than before. But half his face and right shoulder are missing with the above settings… pictures below:
So I thought id adjust some settings and try again…Here is what ill be changing (in bold)
Attempt 7
filename: pilot 07
Extruder: 190 c
Printe Bed: 40 c
Extruding speed: 20mm/s.
Room temp: 18.5 C
I wonder why the hat turned out better, but the face turned out worse. I’ll post results of attempt 7 when I get them.
I don’t think you need to slow it down more than 40mm/s, but if if works it works… the side still looks like a heat problem so try turning off the bed heat all together and see how that turns out.
2 suggestions to try. First try rotating it in the y axis so the face is opposite where the right side is now, it could be that the right side is being exposed to more heat or there is more airflow across the left side. Second, try slicing is along the middle and print it as two halves. This could help since they won’t print so high and change the slice direction some.
try to make two parts that you position with, lets say 50 mmseparation. Resolution high temp at 195 /210 and enhance your cooling. It seems the hat needs support at the front side also, you standard speed
Results from attempt 7 - settings below for reference…
Attempt 7
filename: pilot 07
Extruder: 190 c
Printe Bed: 40 c
Room temp: 18.5 C
It was probably the worst print so far. The body was brittle and there were holes in the model and the lines were quite visible and it didn’t look like it stuck together very well. The head snapped off very easily and the body is brittle and came apart in layers. Whilst the peak of his cap came out very well. the face has no detail and didnt work at all.
If I compare the above settings to the first time i tried to print this model (default ABS settings. 1110 bed temp, 230 extruder temp, 150mm/s travel speed, 90mm/s extruder speed). The ABS settings gave a much better result, by no means perfect, but a lot stronger.
Not sure what to try now. From reading the responses I guess this printer needs modification before something usable is created. I’m going to try one last time to print the pilot before I give up!
Attempt 8 - 2 pilots, 50mm apart
filename: pilot 08
Extruder: 205 c
Printer Bed: 40 c
Room temp: 18.5 C
Not expecting miracles. I did purchase this printer knowing it needs serious modifications before you can get anything usable. But was hoping something half decent would be possible with adding fans and buying Simplify 3D, updating firmware etc…
Hi Eduardo, I downloaded the software, it seems it is a profile editor. I believe I can use notepad to edit the editing. would simplify 3d automatically be able to print the pilot head? does it know to slow down when it gets to smaller areas?
Hi Adam, thanks for the info, I looked at the Google page and it seems that this mod requires you to solder onto a motherboard. With my limited soldering skills this looks a bit tricky.
Do yo uknow of anywhere I can simply buy the ducts and bits to get extra cooling? Or should I just buy one of these desk fans and point it at the printer?
If you want to use notepad, go ahead, but proftweak is simple and easier to use in my opinion. S3d will not do anything automatically, you still have to tell it to slow down and by how much depending on the time it takes per later, you can customize support for just the hat if you want and you can vary the temperature layer by layer on both the nozzle and the heated bed. It’s not a software that you can just click and go though, I took me some time to understand the parameters and what to change and tune to get great prints.
Got ya, I may hold off on s3d for a bit until Ive got to grips with the printer. and got more cooling. Attempt 8 isnt going that well. It seems the back left hand side (Pilots right shoulder) is the bit that is always failing. so far on both pilots that are printing simultaneously the back left parts of the shoulders have holes in them. I wonder why that is? There is no overhang. The part is symmetrical and the Pilots left shoulder is fine.
You’re pointing a house fan at you printer? I hope the real take away here is that no setting will ever overcome a physical hardware (lack of cooling) condition.
Can I just clarify something with regards to how the printing works…
A layer is created, ideally, should this layer be cooled as much as possible before the next layer is printed on top? If I went and bought 5 desk fans and aimed them all at the printer, would that do anything? what about putting the printer outside? it’s 1c currently…
Okay, so basically the printer simply will not work unless I find some way of printing the thingiverse ctc printer fan duct and install an additional 24v fan?
The problem here is that I cannot print the fan modification duct as the printer doesn’t work well enough. You need cooling to print the cooling! Catch 22!
Unfortunately there’s no magic answer here. This will all depend on the type of plastic being used. You will find there is a sweet spot. 5 house fans might be a little overkill, you will need some heat to get good inter later bonding, but then it must cool before the next layer. The print head is also a source of heat that will deform the lower layers. For your particular situation, a fan blowing across the printer, as well as a 20mm cube as tall as your model. This second model will pull the print head away for a bit of time.
The fan pointed at the motherboard is a good source for that fan. It was put there by makerbot to address a voltage regulator problem that our bots don’t suffer from. Generally you print a second duct with your first poorly printed duct, with much better results.
The fact of the situation here, is a rookie user is attempting to print an advanced model on a bottom of the barrel knock off of a clone. I am not saying that this is impossible, but this is not a good start print. Overhangs, unsupported hat brims, facial features, this is a very complex model being printed. Redirecting to Google Groups 4 This is the Google group, that I manage, you might find some good information here. In a much easier to read format.
I have to argue the point about this printer being a bottom of the barrel knock off. I thought this printer was rated the second best printer on 3d hubs? That was the basis on which I bought it.
This is essentially the 3d printing bible. Please follow the calibration steps there. the 20mm 100% infill cube is the proper way to calibrate these machines.
A good rule of thumb for setting filament temps, hotter prints will come glossy, cooler prints will be matte. for high detail PLA printing you will want less of a sheen then appears in your pictures.
Will do! I guess as this is all new to me I’m not sure how good a block can be. Currently trying to print the pilot again, but forgot to turn off 100% infill! So it’s taking a while!
