Jan 2016
Hi - Apologies for creating a new topic, but I couldn’t find any info on this issue, i tried searching printing people, narrower things are broken, but couldn’t find anything on this subject.
I have recently purchased a CTC-3d printer from reading reviews online. I have done the following so far:
- levelled the bed perfectly
- installed the PLA tube that came with it (black)
- printed a 2cm test cube.
It all went quite well. So i thought i’d try and make my own pilot for a dc3 aircraft I am making. The pilot prints fine up to the beak of his hat. and it doesn’t print half his hat at the end.
I have used the settings in the attached image. I dont think the printer has an issue with printing something small. But it seems that its all melted at the top and the layer hasnt got enough time to cool before the next layer so its all messing up.
How do i tell the printer to slow down when the layer is small?
I have attached the actual file in a .gcode format (using “export to file” option in the Makerware settings). If anyone could help that would be swell! :slight_smile:
The pilot head how it is supposed to be -
this is what happens: his head is messed up…
These are my settings:
Pilot Actual Size.gcode (0 Bytes)
Hi Richard, I think for PLA your general heat settings are a bit too high. I usually print PLA with 190° extruder and 60° heatbed temperature. This way it cools down faster. Also very helpful can be to cool the print with a fan.
I am running the Sailfish firmware on my CTC and during the print I can manually adjust the print speed - accelerate or slow it down by any factor. This would certainly help in your case. You could just manually slow down the print speed with factor 0.5 or even less when the printer builds critical parts.
Hmm, that half of the hat doesn’t look like it didn’t print, it looks melted. Lowering the temperature should help this issue. As aurebo mentioned below, 190/60 are more reasonable for PLA. (Small areas tend to get droopy/melty if the temp is too high and/or the print speed is too fast, because it doesn’t have time to dissipate the excess heat as more layers are extruded on top, and that area of the print just starts to melt as the heat builds up.)
Also, Makerware isn’t nearly as smart or flexible as you might need when issues like this arise. Once you get comfortable with your printer, you might consider Simplify3D, it’s pricy but it’s worth every penny!
(And those speeds are a lot higher than I usually run mine at! but YMMV, I suppose. Anyone else’s opinion on print speed?)
Same with me, I typically run mine at max. 50 mm/s. Sometimes slow it down to 20 mm/s or less for optimum results with small parts.
As has been said already.Your heated bed is way too high 110 is for ABS filaments not PLA, you can actually leave the bed temperature at 0 for PLA. If you have problems with adhesion your can use the bed, but never higher than 60 degrees. PLA transfers heat really well, so the bed’s heat radiates though the print, at 110 your layers don’t have any chance to cool enough to be come rigid before the next layer is being applied, which is why it is looking they way it does. Even at 60 your prints could still be too warm from the bed as you get towards the end of your print as well. I would suggest turning the bed to 45 or 50 degrees if you need it.
Every filament is different so dialing in the right temperature for the extruder can be a bit difficult, but in general if it is stringy and droopy, then lower the temperature. If it is rough has lots of gaps in it, you should raise the temperature. Do some small test prints, 200 should where you start, adjust it by 5 degrees up or down at a time to get the temperature right (you should never have to go above 210 or below 190.)
For print speeds, I’ve found that between 50 and 70 mm/s gives me the best results with PLA. I expect that this shouldn’t vary too much based on what I see.
Finally, installing active cooling duct to your printhead really improves print quality. It helps cool the layers quicker so they become rigid and keep their shape better.
I’ve just thoroughly read your response and there’s loads of good information in there. I’ll start at a lower temperature,
ill also reduce the bed to 50. And I’m going to change the red tape that came on the bed to the blue water resistant uv resistant tape. (Not 3m). But it’s blue and has the same properties as 3m tape.
I seem to be the only person who had a ctc printer with red tape! Everyone else seems to have blue!
For preparing you bed after the tape you should use a normal gluestick and apply a thin layer to the tape. This will help the adhesion of the PLA to you bed.
Travel speed can be set fairly high (like 100 or so) but the extrusion speed is the one you should keep between 50-70mm/s
Thanks for the response and help all… I’ve read all the replies and noted some things to try in the short term that in capable of doing. I’ll try the following.
1. Reduce filament heat to 190 (the last attempt was 210 and the head melted even more than the first attempt at 230!?) which doesn’t make sense. I may have got it wrong but lower seemed to be worse.
2. Reduce bed temp to 50 (been using 110). I tried a test print last night at 60 and it came unstuck. Admittedly I did a few other things differently on the time it became unstuck. I tried printing two pilots side by side. Thinking that the extra amount of travel would allow cooling.
3. Reduce the speeds what would good numbers be?
Currently using 150mm/s for travel and 90mm/s extruding I think. I’ve read that people go lower, but what should be 50 and what should be 20? 50 travel an 20 extrude speed?
ill try the above settings and see what happens and post the results . I’ll utilise the same model to keep the results consistent.!
Okay… it’s begun…with the following settings.
Printing same model at the same size to ensure consistency and be able to track progress.
Attempt 06
filename: pilot06
Extruder: 190 c
Printer Bed: 50 c - With Wickes Heavy duty masking tape 3 (interior and exterior)
Speed while travelling: 100mm/s
Extruding speed: 40mm/s.
Room temp: 15.3 C.
Will post results. It will probably take about 2-3 hours.
Updating the firmware is definitely something I will do to control speed. I have seen guides on how to do this, but doesnt look that easy. So will do the straightforward things to start. Inevitably i’m sure i’ll end up updating the firmware to the SailFish.
I’ll also do as you say and add a fan. Ive seen a few different types of fans, it seems some people put perspex sides on the box and a big fan on the side, and some add another fan near the extruder head. this sounds a bit tricky but as i get more prints under my belt i’ll probably do this mod as well!
Apart from all the good adivse you have gotten, to improve maker-ware download prof-tweak from nothing lab. It provides substantially more tuneability, its free. I used it for about 4 month, got comfortable with the printer and was getting very good prints until i wanted the versatilty of s3d for its support. In thingiverse i put a ctc nozzle calibration which really helped me tweak my nozzle with proftweak. Good luck
Okay - So here is attempt 6 results with the following parameters:
Attempt 06
filename: pilot06
Extruder: 190 c
Printer Bed: 50 c - With Wickes Heavy duty masking tape (interior and exterior)
Room temp: 15.3 C.
It all seemed to be going well, It adhered to the tape very well. the Top of the hat came out much better than before. But half his face and right shoulder are missing with the above settings… pictures below:
So I thought id adjust some settings and try again…Here is what ill be changing (in bold)
Attempt 7
filename: pilot 07
Extruder: 190 c
Printe Bed: 40 c
Extruding speed: 20mm/s.
Room temp: 18.5 C
I wonder why the hat turned out better, but the face turned out worse. I’ll post results of attempt 7 when I get them.
hmmmm (confused :-/)
I don’t think you need to slow it down more than 40mm/s, but if if works it works… the side still looks like a heat problem so try turning off the bed heat all together and see how that turns out.
2 suggestions to try. First try rotating it in the y axis so the face is opposite where the right side is now, it could be that the right side is being exposed to more heat or there is more airflow across the left side. Second, try slicing is along the middle and print it as two halves. This could help since they won’t print so high and change the slice direction some.
try to make two parts that you position with, lets say 50 mmseparation. Resolution high temp at 195 /210 and enhance your cooling. It seems the hat needs support at the front side also, you standard speed
happy printing
Results from attempt 7 - settings below for reference…
Attempt 7
filename: pilot 07
Extruder: 190 c
Printe Bed: 40 c
Room temp: 18.5 C
It was probably the worst print so far. The body was brittle and there were holes in the model and the lines were quite visible and it didn’t look like it stuck together very well. The head snapped off very easily and the body is brittle and came apart in layers. Whilst the peak of his cap came out very well. the face has no detail and didnt work at all.
If I compare the above settings to the first time i tried to print this model (default ABS settings. 1110 bed temp, 230 extruder temp, 150mm/s travel speed, 90mm/s extruder speed). The ABS settings gave a much better result, by no means perfect, but a lot stronger.
Not sure what to try now. From reading the responses I guess this printer needs modification before something usable is created. I’m going to try one last time to print the pilot before I give up!
Attempt 8 - 2 pilots, 50mm apart
filename: pilot 08
Extruder: 205 c
Printer Bed: 40 c
Room temp: 18.5 C
Not expecting miracles. I did purchase this printer knowing it needs serious modifications before you can get anything usable. But was hoping something half decent would be possible with adding fans and buying Simplify 3D, updating firmware etc…
Hi Eduardo, I downloaded the software, it seems it is a profile editor. I believe I can use notepad to edit the editing. would simplify 3d automatically be able to print the pilot head? does it know to slow down when it gets to smaller areas?
Hi Adam, thanks for the info, I looked at the Google page and it seems that this mod requires you to solder onto a motherboard. With my limited soldering skills this looks a bit tricky.
So i did a bit of research and found a 3d printable Fan mount that mounts to the carriage 2. However in order to print this fan mount you need a printer wiht cooling! seems like a bit of a catch 22.
Do yo uknow of anywhere I can simply buy the ducts and bits to get extra cooling? Or should I just buy one of these desk fans and point it at the printer?
Cheers, R
If you want to use notepad, go ahead, but proftweak is simple and easier to use in my opinion. S3d will not do anything automatically, you still have to tell it to slow down and by how much depending on the time it takes per later, you can customize support for just the hat if you want and you can vary the temperature layer by layer on both the nozzle and the heated bed. It’s not a software that you can just click and go though, I took me some time to understand the parameters and what to change and tune to get great prints.
Got ya, I may hold off on s3d for a bit until Ive got to grips with the printer. and got more cooling. Attempt 8 isnt going that well. It seems the back left hand side (Pilots right shoulder) is the bit that is always failing. so far on both pilots that are printing simultaneously the back left parts of the shoulders have holes in them. I wonder why that is? There is no overhang. The part is symmetrical and the Pilots left shoulder is fine.
Doesn’t seem to make logical sense to me…!
You’re pointing a house fan at you printer? I hope the real take away here is that no setting will ever overcome a physical hardware (lack of cooling) condition.
Do not point fans at it, that will cool the extruded and your print will fail due to clogging or the firmware will stop the print for the inconsistent heating
The fact of the situation here, is a rookie user is attempting to print an advanced model on a bottom of the barrel knock off of a clone. I am not saying that this is impossible, but this is not a good start print. Overhangs, unsupported hat brims, facial features, this is a very complex model being printed. Redirecting to Google Groups 4 This is the Google group, that I manage, you might find some good information here. In a much easier to read format.
Hi Adam, agreed, I certainly am a rookie user!
I didn’t know that the model i was attempting to print was an advanced model, I thought it didn’t matter what it was you just load the model and print it. and if the temperatures are correct and bed is levelled, everything should pretty much work out of the box. But since learning that the model I am trying to print is a bit more of an advanced model it makes me feel a bit better that I cant get it to work after 8 attempts!
I’ll do as I’ve been told as well and calibrate the nozzle, download proftweak, and make some pillow blocks. I’ll get on over to your group on Google as i presume i’m not the only person struggling to get good results with this printer.
I have to argue the point about this printer being a bottom of the barrel knock off. I thought this printer was rated the second best printer on 3d hubs? That was the basis on which I bought it. :frowning:
That is the next thing on my list. I figured i’d get the basics done right, like levelling the bed and getting the temps right. but yes this is important. I’m not sure what the extrusion multiplier is?
I have downloaded, installed and run prof tweak. I have duplicated a profile (the Makerbot PLA Standard) and saved it. and opened my new custom profile in Proftweak, and can see all the different settings.
I’ll get on with calibrating the nozzles and i’ll also download and print pillow blocks (i’m not sure what these are yet!)
With regards to Nozzle calibration. from my Googling it seems like the Nozzle calibration is to calibrate the distance between the two extruders. I found a post on thingiverse about nozzle calibration. But it doesnt say how do do it, or what model to print. Is there a guide anywhere on how to calibrate the nozzle?
Thanks for your patience!
I will disagree with this being a bottom of the barrel knock off. This printer is the best for its price you can get. Mine prints just as good or better than a maker not and I have used a maker it before. Needless to say I did some mods that make the printer substantially better but it was all printed with the same printer so to me that is a win win. I printed a better extruded block, y pillow block, glass bed, filament guide and sailfish no nozzle calibration with s3d. With those mods I can set it and forget it with confidence that it will print. So again, this is. Great printer that just needs minor mods that you can print yourself and make it better it just as good as a maker bot. At the end of the day calibration and tuning for every model is essential for good prints. The more you print the more you know what works and what does not. Also according to how the models print you can tell what needs to be tuned to make the model better. This comes with experience though. We are all happy to help and I think you made a good choice in printer.
Hi Eduardo, when I search that it comes up with a small round model … And instructions for prof tweaks.
nowhere on the page is it clear what you actually need to do, what do you do? Print the model? In the link? Measure what? It doesn’t make any sense to me, the chap who made the model in the link said he followed the instructions, what instructions is he on about. I really don’t understand. And I can’t seem to find percentage multipliers in prof tweaks either!
am I missing something here?
OK, lets all just take a step back and get to be friends again. CTC is an copy of an open source design, they took from flashforge. CTC as a company does not have the best reputation, in my opinion ( i don’t want to be threatened by another employee of CTC with litigation ). If you look at the 3dhubs results, from past years, you will see people being very happy with the output of the printer but lacking quality control from the factory. My printer came from the factory with un-insulated wiring to the heater cores, blowing up my motherboard. As to being the bottom of the barrel in the rep 1 clone world, well there is the monoprice version that has no heated bed, but this printer has not kept up with the advances of either flashforge or Wanhao. The current crop of clones now come with all metal Z stages, improved filament pusher drives, more durable 4x2 ptfe liners, not to mention mighty-boards equipped with 2560 processor, led drivers, extra cooling fan mosfet installed. You even said yourself that you had to do all these “mods” to get it to work. With all that being said, its a fine printer that once you really get to know it, and how it works you will be very happy with it. After owning mine for about 2 years it is the plug and play machine that I anticipated buying, but it was definitely a frustrating journey.
What are you slicing with? makerbot has become more and more hostile to the clones and burying settings deep inside makerware. I don’t personally use it, I use S3d, so I can give you and advice there. I have read reports of needed up open python eggs and recompile them to change some things. If you would like a copy of makerware 2.4, the last version to contain an update pertinent to our machines email me at adamcooksatgmaildotcom and I will send you a link, its a free dropbox account so i wont post that link publicly.
That’s mine. I made the model and instructions. If you go under instructions it says what to do and what to set in proftweAk. I’ll try and take some images later
I am not arguing. I am not a Ctc employee. I am just happy with what I bought and think it’s a decent machine for what I paid. I agree with all your statement but the price for a flash forge or a wanhoo in comparison to a Ctc is almost double. So again yea the printer lacks many things and Ctc could have a much better product out of the box if they applied quality control and some slight design changes. I am just a happy customer that after having my machine for a year I can print anything I want in any material and not have to baby sit. I burned my mb too. My fault since I shorted the heater cartridge by mistake. But you live and learn. It’s a frustrating journey, I agree but once you get to know the printer it works rather well. S3d makes a huge difference as well. Cuts set up time and prints so much better. No one is arguing here Adam.
Hi Eduardo, the link to the page on Sailfish was very helpful and I was able to follow the instructions…
My filament was 1.80mm not 1.75mm as it should be.
I have printed the box at standard speed (90mm/s extrude, 150mm/s travel). And the box seems to miss some of the top lines. so I reduced the Feedstock multiplier by 0.05 to 1.0.
the roof is nice and flat - the box is 19.69mm x 19.38mm - I guess its nearly impossible to get it to print at 20mm to match the size on the computer.
At least all the lines on the roof are present. but there are gaps in between them. It seems that it is not over or under extruding as the roof is flat. - see IMG_0508. - temp was 200c
I then chose to increase the temperature from 200 to 205, but leave everything else the same. the print has come out a little better than the 200c print. - See IMG_0510.
After calibrating the nozzles, i’ll try the pilot again and see what happens
Will do! I guess as this is all new to me I’m not sure how good a block can be. Currently trying to print the pilot again, but forgot to turn off 100% infill! So it’s taking a while!
