Jan 2016
I don’t think you need to slow it down more than 40mm/s, but if if works it works… the side still looks like a heat problem so try turning off the bed heat all together and see how that turns out.
2 suggestions to try. First try rotating it in the y axis so the face is opposite where the right side is now, it could be that the right side is being exposed to more heat or there is more airflow across the left side. Second, try slicing is along the middle and print it as two halves. This could help since they won’t print so high and change the slice direction some.
try to make two parts that you position with, lets say 50 mmseparation. Resolution high temp at 195 /210 and enhance your cooling. It seems the hat needs support at the front side also, you standard speed
happy printing
The fan pointed at the motherboard is a good source for that fan. It was put there by makerbot to address a voltage regulator problem that our bots don’t suffer from. Generally you print a second duct with your first poorly printed duct, with much better results.
The fact of the situation here, is a rookie user is attempting to print an advanced model on a bottom of the barrel knock off of a clone. I am not saying that this is impossible, but this is not a good start print. Overhangs, unsupported hat brims, facial features, this is a very complex model being printed. Redirecting to Google Groups 4 This is the Google group, that I manage, you might find some good information here. In a much easier to read format.
Hi Adam, agreed, I certainly am a rookie user!
I have to argue the point about this printer being a bottom of the barrel knock off. I thought this printer was rated the second best printer on 3d hubs? That was the basis on which I bought it. :frowning:
Thanks for your patience!
am I missing something here?
Will do! I guess as this is all new to me I’m not sure how good a block can be. Currently trying to print the pilot again, but forgot to turn off 100% infill! So it’s taking a while!
Will do, it seems the fan duct needs to be made from ABS, not PLA, so will need to order a roll of ABS to make the fan duct.
I tried the pilot again after calibrating the nozzles… bad things happened, he doesn’t have a head!
The temp was 205, thought I’d increase it a bit to try and remove the broken layering. But that didn’t seem to work that well! if anything it made the layering even worse. It comes apart in layers easily.
Definitely need the cooling!
I use a PLA printed cooling duct and don’t have any issues, though I do need to replace it sometimes because it does warp from the heat overtime (something like every 6 months or so.) I printed my first duct very slowly, it wasn’t prefect but it was good enough to make it so I could print a second duct at a normal speed without any troubles and since that quality is only getting better.
It still look like you are printing too hot, and it could be that you are printing to slowly now too. It sucks but for the first little while there is a lot of trial and error in getting the printer’s settings figured out. On my printer I generally get the best layer results when my feedrate is between 50 and 70 mm/s. Try changing your infill from honeycomb to rectangle. It will save time and filament (and be just as strong with less vibration during your printing.) As for removing layers during a print that will more often cause the print to fail than save it. It’s better to stop the print and start over, it sucks but sometimes that is all you can do.
Hi guys for anyone reading this post. I have finally got good quality prints by doing the following…
- Install Makerware 3.8
- Print on standard settings, but change the following values, Extruder temp:222c for the PLA that comes with the printer, and Setting minimum layer time to 30s.
- I’ve left the filament diameter at the default setting (1.75) - although the filament is 1.79. Changing to 1.79 doesn’t seem to make a difference. I’ve also left the extrusion multiplier at the default of 0.93.
I’m now printing perfect pilots every time.
It seems it was a simple case of raising the temp for the PLA to 222, and slowing the layer time to 30s. Makerware 3.8 Beta is much better.
I’m sure that ensuring the printer isn’t over or under extruding is important, but doesn’t seem to be a contributing factor in the pilots i’m doing. I probably need to revisit the cubes as they are 19mm across, not 20mm. So when i come to needing to print accurately sized parts that slot together, getting it accurate will be important, but for people these settings seem pretty good.
Makerware 3.8 gives you the ability to change all the settings without having to use proftweaks.
1 month later
I’ve semi perfected printing in PLA now. good enough for what I need at least. They are no works of art, but they’ll do nicely. Im now moving to the dark art of ABS.
Quick question. Which version of makerware desktop do you guys use? Since upgrading from 3.8 to 3.9, the left extruder has started working, but for some reason i get another structure next to the main piece… and ideas?
