Got ya, I may hold off on s3d for a bit until Ive got to grips with the printer. and got more cooling. Attempt 8 isnt going that well. It seems the back left hand side (Pilots right shoulder) is the bit that is always failing. so far on both pilots that are printing simultaneously the back left parts of the shoulders have holes in them. I wonder why that is? There is no overhang. The part is symmetrical and the Pilots left shoulder is fine.
Doesn’t seem to make logical sense to me…!
You’re pointing a house fan at you printer? I hope the real take away here is that no setting will ever overcome a physical hardware (lack of cooling) condition.
Can I just clarify something with regards to how the printing works…
A layer is created, ideally, should this layer be cooled as much as possible before the next layer is printed on top? If I went and bought 5 desk fans and aimed them all at the printer, would that do anything? what about putting the printer outside? it’s 1c currently…
Okay, so basically the printer simply will not work unless I find some way of printing the thingiverse ctc printer fan duct and install an additional 24v fan?
The problem here is that I cannot print the fan modification duct as the printer doesn’t work well enough. You need cooling to print the cooling! Catch 22!
Unfortunately there’s no magic answer here. This will all depend on the type of plastic being used. You will find there is a sweet spot. 5 house fans might be a little overkill, you will need some heat to get good inter later bonding, but then it must cool before the next layer. The print head is also a source of heat that will deform the lower layers. For your particular situation, a fan blowing across the printer, as well as a 20mm cube as tall as your model. This second model will pull the print head away for a bit of time.
The fan pointed at the motherboard is a good source for that fan. It was put there by makerbot to address a voltage regulator problem that our bots don’t suffer from. Generally you print a second duct with your first poorly printed duct, with much better results.
The fact of the situation here, is a rookie user is attempting to print an advanced model on a bottom of the barrel knock off of a clone. I am not saying that this is impossible, but this is not a good start print. Overhangs, unsupported hat brims, facial features, this is a very complex model being printed. Redirecting to Google Groups This is the Google group, that I manage, you might find some good information here. In a much easier to read format.
Hi Adam, agreed, I certainly am a rookie user!
I have to argue the point about this printer being a bottom of the barrel knock off. I thought this printer was rated the second best printer on 3d hubs? That was the basis on which I bought it.
Ah haa - I get you. I’ll get all the nuts and bolts mentioned on the Google link above and do that mod as well.
Thanks for your patience!
Search Ctc nozzle calibration
am I missing something here?
http://www.sailfishfirmware.com/doc/tuning-slicer-calibration.html#x27-670005.1
This is essentially the 3d printing bible. Please follow the calibration steps there. the 20mm 100% infill cube is the proper way to calibrate these machines.
A good rule of thumb for setting filament temps, hotter prints will come glossy, cooler prints will be matte. for high detail PLA printing you will want less of a sheen then appears in your pictures.
