Jan 2016
You’re pointing a house fan at you printer? I hope the real take away here is that no setting will ever overcome a physical hardware (lack of cooling) condition.
Can I just clarify something with regards to how the printing works…
A layer is created, ideally, should this layer be cooled as much as possible before the next layer is printed on top? If I went and bought 5 desk fans and aimed them all at the printer, would that do anything? what about putting the printer outside? it’s 1c currently…
