This is essentially the 3d printing bible. Please follow the calibration steps there. the 20mm 100% infill cube is the proper way to calibrate these machines.
A good rule of thumb for setting filament temps, hotter prints will come glossy, cooler prints will be matte. for high detail PLA printing you will want less of a sheen then appears in your pictures.
