Jan 2016
I don’t think you need to slow it down more than 40mm/s, but if if works it works… the side still looks like a heat problem so try turning off the bed heat all together and see how that turns out.
2 suggestions to try. First try rotating it in the y axis so the face is opposite where the right side is now, it could be that the right side is being exposed to more heat or there is more airflow across the left side. Second, try slicing is along the middle and print it as two halves. This could help since they won’t print so high and change the slice direction some.
try to make two parts that you position with, lets say 50 mmseparation. Resolution high temp at 195 /210 and enhance your cooling. It seems the hat needs support at the front side also, you standard speed
happy printing
Results from attempt 7 - settings below for reference…
Attempt 7
filename: pilot 07
Extruder: 190 c
Printe Bed: 40 c
Speed while travelling: 100mm/s
Extruding speed: 20mm/s.
Room temp: 18.5 C
It was probably the worst print so far. The body was brittle and there were holes in the model and the lines were quite visible and it didn’t look like it stuck together very well. The head snapped off very easily and the body is brittle and came apart in layers. Whilst the peak of his cap came out very well. the face has no detail and didnt work at all.
If I compare the above settings to the first time i tried to print this model (default ABS settings. 1110 bed temp, 230 extruder temp, 150mm/s travel speed, 90mm/s extruder speed). The ABS settings gave a much better result, by no means perfect, but a lot stronger.
Not sure what to try now. From reading the responses I guess this printer needs modification before something usable is created. I’m going to try one last time to print the pilot before I give up!
Attempt 8 - 2 pilots, 50mm apart
filename: pilot 08
Extruder: 205 c
Printer Bed: 40 c
Room temp: 18.5 C
Not expecting miracles. I did purchase this printer knowing it needs serious modifications before you can get anything usable. But was hoping something half decent would be possible with adding fans and buying Simplify 3D, updating firmware etc…
Hi Eduardo, I downloaded the software, it seems it is a profile editor. I believe I can use notepad to edit the editing. would simplify 3d automatically be able to print the pilot head? does it know to slow down when it gets to smaller areas?
Hi Adam, thanks for the info, I looked at the Google page and it seems that this mod requires you to solder onto a motherboard. With my limited soldering skills this looks a bit tricky.
So i did a bit of research and found a 3d printable Fan mount that mounts to the carriage 2. However in order to print this fan mount you need a printer wiht cooling! seems like a bit of a catch 22.
Do yo uknow of anywhere I can simply buy the ducts and bits to get extra cooling? Or should I just buy one of these desk fans and point it at the printer?
Cheers, R
If you want to use notepad, go ahead, but proftweak is simple and easier to use in my opinion. S3d will not do anything automatically, you still have to tell it to slow down and by how much depending on the time it takes per later, you can customize support for just the hat if you want and you can vary the temperature layer by layer on both the nozzle and the heated bed. It’s not a software that you can just click and go though, I took me some time to understand the parameters and what to change and tune to get great prints.
Unfortunately there’s no magic answer here. This will all depend on the type of plastic being used. You will find there is a sweet spot. 5 house fans might be a little overkill, you will need some heat to get good inter later bonding, but then it must cool before the next layer. The print head is also a source of heat that will deform the lower layers. For your particular situation, a fan blowing across the printer, as well as a 20mm cube as tall as your model. This second model will pull the print head away for a bit of time.
The fan pointed at the motherboard is a good source for that fan. It was put there by makerbot to address a voltage regulator problem that our bots don’t suffer from. Generally you print a second duct with your first poorly printed duct, with much better results.
The fact of the situation here, is a rookie user is attempting to print an advanced model on a bottom of the barrel knock off of a clone. I am not saying that this is impossible, but this is not a good start print. Overhangs, unsupported hat brims, facial features, this is a very complex model being printed. Redirecting to Google Groups 4 This is the Google group, that I manage, you might find some good information here. In a much easier to read format.
Hi Adam, agreed, I certainly am a rookie user!
I have to argue the point about this printer being a bottom of the barrel knock off. I thought this printer was rated the second best printer on 3d hubs? That was the basis on which I bought it. :frowning:
Thanks for your patience!
am I missing something here?
Will do! I guess as this is all new to me I’m not sure how good a block can be. Currently trying to print the pilot again, but forgot to turn off 100% infill! So it’s taking a while!
Will do, it seems the fan duct needs to be made from ABS, not PLA, so will need to order a roll of ABS to make the fan duct.
I tried the pilot again after calibrating the nozzles… bad things happened, he doesn’t have a head!
The temp was 205, thought I’d increase it a bit to try and remove the broken layering. But that didn’t seem to work that well! if anything it made the layering even worse. It comes apart in layers easily.
Definitely need the cooling!
