As has been said already.Your heated bed is way too high 110 is for ABS filaments not PLA, you can actually leave the bed temperature at 0 for PLA. If you have problems with adhesion your can use the bed, but never higher than 60 degrees. PLA transfers heat really well, so the bed’s heat radiates though the print, at 110 your layers don’t have any chance to cool enough to be come rigid before the next layer is being applied, which is why it is looking they way it does. Even at 60 your prints could still be too warm from the bed as you get towards the end of your print as well. I would suggest turning the bed to 45 or 50 degrees if you need it.
Every filament is different so dialing in the right temperature for the extruder can be a bit difficult, but in general if it is stringy and droopy, then lower the temperature. If it is rough has lots of gaps in it, you should raise the temperature. Do some small test prints, 200 should where you start, adjust it by 5 degrees up or down at a time to get the temperature right (you should never have to go above 210 or below 190.)
For print speeds, I’ve found that between 50 and 70 mm/s gives me the best results with PLA. I expect that this shouldn’t vary too much based on what I see.
Finally, installing active cooling duct to your printhead really improves print quality. It helps cool the layers quicker so they become rigid and keep their shape better.
I’ve just thoroughly read your response and there’s loads of good information in there. I’ll start at a lower temperature,
ill also reduce the bed to 50. And I’m going to change the red tape that came on the bed to the blue water resistant uv resistant tape. (Not 3m). But it’s blue and has the same properties as 3m tape.
I seem to be the only person who had a ctc printer with red tape! Everyone else seems to have blue!
Hi Eduardo, I downloaded the software, it seems it is a profile editor. I believe I can use notepad to edit the editing. would simplify 3d automatically be able to print the pilot head? does it know to slow down when it gets to smaller areas?
Hi Adam, thanks for the info, I looked at the Google page and it seems that this mod requires you to solder onto a motherboard. With my limited soldering skills this looks a bit tricky.
Do yo uknow of anywhere I can simply buy the ducts and bits to get extra cooling? Or should I just buy one of these desk fans and point it at the printer?
If you want to use notepad, go ahead, but proftweak is simple and easier to use in my opinion. S3d will not do anything automatically, you still have to tell it to slow down and by how much depending on the time it takes per later, you can customize support for just the hat if you want and you can vary the temperature layer by layer on both the nozzle and the heated bed. It’s not a software that you can just click and go though, I took me some time to understand the parameters and what to change and tune to get great prints.
Got ya, I may hold off on s3d for a bit until Ive got to grips with the printer. and got more cooling. Attempt 8 isnt going that well. It seems the back left hand side (Pilots right shoulder) is the bit that is always failing. so far on both pilots that are printing simultaneously the back left parts of the shoulders have holes in them. I wonder why that is? There is no overhang. The part is symmetrical and the Pilots left shoulder is fine.
You’re pointing a house fan at you printer? I hope the real take away here is that no setting will ever overcome a physical hardware (lack of cooling) condition.
Can I just clarify something with regards to how the printing works…
A layer is created, ideally, should this layer be cooled as much as possible before the next layer is printed on top? If I went and bought 5 desk fans and aimed them all at the printer, would that do anything? what about putting the printer outside? it’s 1c currently…
Okay, so basically the printer simply will not work unless I find some way of printing the thingiverse ctc printer fan duct and install an additional 24v fan?
The problem here is that I cannot print the fan modification duct as the printer doesn’t work well enough. You need cooling to print the cooling! Catch 22!
Unfortunately there’s no magic answer here. This will all depend on the type of plastic being used. You will find there is a sweet spot. 5 house fans might be a little overkill, you will need some heat to get good inter later bonding, but then it must cool before the next layer. The print head is also a source of heat that will deform the lower layers. For your particular situation, a fan blowing across the printer, as well as a 20mm cube as tall as your model. This second model will pull the print head away for a bit of time.
The fan pointed at the motherboard is a good source for that fan. It was put there by makerbot to address a voltage regulator problem that our bots don’t suffer from. Generally you print a second duct with your first poorly printed duct, with much better results.
The fact of the situation here, is a rookie user is attempting to print an advanced model on a bottom of the barrel knock off of a clone. I am not saying that this is impossible, but this is not a good start print. Overhangs, unsupported hat brims, facial features, this is a very complex model being printed. Redirecting to Google Groups 4 This is the Google group, that I manage, you might find some good information here. In a much easier to read format.
I have to argue the point about this printer being a bottom of the barrel knock off. I thought this printer was rated the second best printer on 3d hubs? That was the basis on which I bought it.
This is essentially the 3d printing bible. Please follow the calibration steps there. the 20mm 100% infill cube is the proper way to calibrate these machines.
A good rule of thumb for setting filament temps, hotter prints will come glossy, cooler prints will be matte. for high detail PLA printing you will want less of a sheen then appears in your pictures.
Will do! I guess as this is all new to me I’m not sure how good a block can be. Currently trying to print the pilot again, but forgot to turn off 100% infill! So it’s taking a while!
Will do, it seems the fan duct needs to be made from ABS, not PLA, so will need to order a roll of ABS to make the fan duct.
I tried the pilot again after calibrating the nozzles… bad things happened, he doesn’t have a head!
The temp was 205, thought I’d increase it a bit to try and remove the broken layering. But that didn’t seem to work that well! if anything it made the layering even worse. It comes apart in layers easily.
I use a PLA printed cooling duct and don’t have any issues, though I do need to replace it sometimes because it does warp from the heat overtime (something like every 6 months or so.) I printed my first duct very slowly, it wasn’t prefect but it was good enough to make it so I could print a second duct at a normal speed without any troubles and since that quality is only getting better.
It still look like you are printing too hot, and it could be that you are printing to slowly now too. It sucks but for the first little while there is a lot of trial and error in getting the printer’s settings figured out. On my printer I generally get the best layer results when my feedrate is between 50 and 70 mm/s. Try changing your infill from honeycomb to rectangle. It will save time and filament (and be just as strong with less vibration during your printing.) As for removing layers during a print that will more often cause the print to fail than save it. It’s better to stop the print and start over, it sucks but sometimes that is all you can do.
Hi guys for anyone reading this post. I have finally got good quality prints by doing the following…
- Install Makerware 3.8
- Print on standard settings, but change the following values, Extruder temp:222c for the PLA that comes with the printer, and Setting minimum layer time to 30s.
- I’ve left the filament diameter at the default setting (1.75) - although the filament is 1.79. Changing to 1.79 doesn’t seem to make a difference. I’ve also left the extrusion multiplier at the default of 0.93.
I’m now printing perfect pilots every time.
It seems it was a simple case of raising the temp for the PLA to 222, and slowing the layer time to 30s. Makerware 3.8 Beta is much better.
I’m sure that ensuring the printer isn’t over or under extruding is important, but doesn’t seem to be a contributing factor in the pilots i’m doing. I probably need to revisit the cubes as they are 19mm across, not 20mm. So when i come to needing to print accurately sized parts that slot together, getting it accurate will be important, but for people these settings seem pretty good.
Makerware 3.8 gives you the ability to change all the settings without having to use proftweaks.
I’ve semi perfected printing in PLA now. good enough for what I need at least. They are no works of art, but they’ll do nicely. Im now moving to the dark art of ABS.
Quick question. Which version of makerware desktop do you guys use? Since upgrading from 3.8 to 3.9, the left extruder has started working, but for some reason i get another structure next to the main piece… and ideas?
