Oct 2016
Hi G,
What problems are you having. I just started a print and it stalls for no reason after a few seconds/minutes.
For info our build is shown in the attached. The base cover is off because I anticipate that a new board is required - can’t update the firmware on this one.
Out of interest I bought a RepRap DIY from china (£200 quid’ish) as my first 3d printer earlier this year. It looks like something from Robot Wars (after the battle that is) but it trumps all over the V3 for print size, ease of construction and software compatibility.
Hi Fawksey,
I was also diagnosed with a faulty board.
It took them around 6 weeks to send out a replacement, which solved the original problem.
Unfortunately the new board came ready with its own problems which differ to the original problems!
Hi i had the same problem but then found i had fitted the brackets on the wrong side instead of between the fan and block this raised the fan blower but the clearance is very small and i did need to bend the brackets a little but all works fine now
Is anyone having any problems with grub screws coming loose after a few prints? which then causes the printing to go out of line and I wondered if anyone had any solutions for that? I am thinking metal glue
Well i have fixed it by removing the bottom screw of the plastic plate/grip that holds the limit switch in place. Pushinh it as far right as possible and glueing it in place. Its just because its about 1mm out. You can test it by moving the x-axis left and right to make sure the limit switch clicks when it reaches the end
Ive found you can buy grub screws online woth threaded locks to stop them coming undone with vibrations. Im guna give that ago if not threaded lock glue seems the way
Graham, the problem with the damn thing still vibrates as the printer head tries to go further to the left than its supposed to is a problem with the limit switch not being being pressed in fully, I put my fix below. You need to make sure it fully clicks as the print nozzle arm inside the metal case pushes the limit switch down.
If it is fully clicking and being hit every time and not being pushed back away then you will have a problem with the limit switch but either way thats what the limit switch is for and that is the reason, it is there to say " this is the end, stop moving in this direction "
Hi All
I know that some of us are having issues with this printer, however if you do manage to get it to work here are some tips.
Firstly forget the slicing system in the printers software just use it as a way to connect to your printer, send the g_codes.
download
Meshmixer at www.meshmixer.com
Slic3r at http://slic3r.org
Meshlab at http://meshlab.sourceforge.net
Now I use Meshmixer to add the support structure to the Model, Slic3r to generate the g_code then upload with 3d create and print.
now Meshlab I use to convert the sketchup file to stl as sometimes the sketchup plugin fails.
Here are the settings for PLA in Slic3r I use which seem to work.
In Print Settings
Layers & Perimeters
Layer Height 0.2
First layer Height 0.2
Perimeter 3
Solid layers top and bottom 3
Seam position random
Infill
Fill density between 25% and 80% depending how strong you want the Model
Fill Pattern Honeycomb
Top & Bottom Fill pattern Rectilinear
Combine every fill layer 1
Only when needed tick
Solid infill layer 3
Fill angle 45 degrees
Solid infill threshold 70 mm2
Infill before perimeter tick
Skirt And Brim
Loops 4
Distance from object 4
Skirt height 1
Minimum Extrusion length 0
Brim width 0
Support Material
Make sure it is not ticked as you will get better results from Meshmix do look on youtube for tutorials.
Speed
Perimeters 30
Small Perimeters 20
External Perimeters 15
Infill 50
Solid Infill 50
Top Solid Infill 50
Support Material 50
Support Material Interface 60
Bridges 60
Gap Fill 20
Travel 80
First Layer Speed 30
The rest of the settings make sure they are set to 0 except Max Print Speed set to 80
Multiple Extruders
Make sure the settings are set to 1 and the tick boxes are empty
Advanced
Make sure all settings are set to 0 except these settings
First Layer 200%
Infill Perimeter Overlap 20%
Bridge Flow Ratio 1
Threads 2
That’s all the setting for this section
Filament Settings
You need to set that according to the material you are using and the recommended settings**.**
Printer Settings
General
Bed Shape Rectangular
Size 140 X 140
Origin 0 0
Extruders 1
G-Code Flavor RepRap
Pressure Advance 0
Vibration Limit 0
Custom G Codes leave alone
Extruder 1
Nozzel Diameter 0.4
Extruder Offset 0 & 0
Length 1.5
Lift Z 0.5
Speed 20
Extra Length On Restart 0
Minimum travel after retraction 1.5
The two boxes not ticked
Length 10
Extra length on restart 0
This should set you up for printing
When you do load the G-code the printer will tell you the bed is heating , But it will not mention the print head. Just let it run.
Now as for the Printer
That square PCB build plate get shot of it as it is useless.
Get hold of some sheet Aluminum the same size as the PCB. Rough the surface with some 80 grit emery paper.
When you get ready to to print spray the Aluminum with cheap Hair Spray, this will help combat warping.
I have added a Photo of the results.
Do search for tutorials on the software packages I have mentioned, but ultimately get a better printer for half the price we had to pay for this thing.
Thankyou
Will be glad to move away from the V3 Just rebuilding my Prusa I3 onto a 3mm Steel Frame.
Then I will Probably donate this V3 to My child’s School where Precision is not an issue.
I’m ever the optimist…
I had one great print from this printer two days ago, and I thought I had cracked it.
Mmmm not the case how wrong could I have been as the next few prints started to degrade, and I thought it was my settings.
Tonight I started a print to discover the bed was not positioning to where I had calibrated it so I went through the process again, and found it was significantly off.
After closer inspection of the z axis I found that it alters its position, and this is due to the flimsy construction. I should not be able to move the axis by hand by 10mm. No wonder every photo of prints show visible ghosting.
I do not know what the answer is for this one I think I shall have to either gut it for parts or use it as a door stop, but I cannot risk the print quality
I must be one of the lucky ones my printer is working fine even the software from Eaglemoss is working OK the only problem I have is the bed will not heat but with the use of masking tape and Ridge Ink PLA sticks to the bed well.
I did fine the calibration was hard and took some time but the bed has not moved and is still working after a number of prints.I also had a problem with the extra fan as the vent part did catch on the bed plate when first fitted but a small amount of bending the holding brackets solved this.
I did find that if I printed a large circle 125 dia and 1mm deep helped with the calibration as it was better to seen any errors.
