I am just about ready to give up. I have a chinese brand Kossel Mini which I received a week ago and did all the assembly and bed leveling. For the first 3 days it printed great, I have attached couple of prints, then for the last 3 days nothing but a headach… the filament keeps getting stuck and the extruder bearing either ends up chewing it or not spinning at all. I am not getting consistent even feed rates either I will have layers with too little as compared to other so there will be delamination of the plastic. I did not have these problems the first 3 days of printing and everything was going great. I have attached photos of prints from the first few days I had the printer up, running, and well leveled.
Then about 3 days ago now it started feeding inconsistently and jamming and sticking. Now last night I took the whole hot end assembly apart and cleaned it all and put on a new nozzle and still the same thing keeps happening. I measured the filament in various sections and the diameter ranges from 1.5mm up to 196mm. It also is not perfect circumference for example if i measure a spot and get 1.54 then at the same spot measure the perpendicular i might get 1.74. I am not sure what it is. I don’t know if it is my extruder, my hot end/assembly, the filament. I have been testing with various temps. All my successful prints have been with 205-220 for temps. In one of my attached photos I circle the most common area for the pla jamming up.
I dont know if I should by another hot end assembly or if the filament is shit, am I using too high a temp for the pla, if so why so many decent prints at that temp and now this
created
Feb '16last reply
Feb '16- 36
- 6.2k
likes
- 1
link
