Feb 2016
Yes It printed fine for a few days until I got almost halfway into the reel. I only have a couple meters of blue sample that came with the printer kit. I will not order from this manufacture again, they are called MG Chemicals, I purchased on Amazon.ca.
While the filament thickness issues are certainly a red flag, I’ll offer a couple more things to check, based on my having the same issues a while back. I mean, you got some successful prints, and then things went bad. Sounds very familiar… I think I’ve actually had all of these problems at the same time before:
1) Check gears on your extruder drive and make sure there is no loose play at all in their movement. If either of the plastic gears turn independently of the other, or of the motor spindle, that’s bad. Even just a mm’s worth. In my case, the plastic at the center of the large gear started wearing out so that it wasn’t locked onto the hex screw holding it in place. So as a print extrudes and retracts, back and forth, it eventually gets to a place where there are so many retractions in a short period of time, that the gears are turning back and forth without actually driving any filament forward. I super glued it together long enough to print a new gear and mount it better (with a bead of super glue from the get-go.)
2) Make sure the hobbed gear is clean – grinding on filament fills the grooves and the teeth don’t grab like they used to.
3) Too high of a retraction distance. I’ve seen advice particularly about keeping the value low for PLA (1.2mm or less, YMMV), as it’s kinda sticky, and if you get too many retractions in a row (most slicing apps have settings for mitigating that situation), it can pull it up into the cold part of your hot-end assembly, cooling the PLA and jamming it up above your hot end.
4) Cross-wound filament. I often re-wind a new spool of filament manually onto another spool, because there are often spots where it’s been wound so tight by the manufacturer that the extruder can’t pull off the spool. Then it just grinds away on that one spot. But that problem would likely have been obvious.
5) A crazy thing I would have never guessed to try – I tried this piece of advice and it seems to be working – reduce the current to your extruder motor when using PLA (and back up again for ABS.) Go into your firmware and find the setting:
#define DIGIPOT_MOTOR_CURRENT {135,135,135,135,135}
and adjust one or both of the last two 135’s (extruder 0 and extruder 1.) “135” represents a value from 0 to 255, where in my Marlin firmware 135 => ~0.75A. I use 85 to have it pull about 0.5A. This will allow the motor to slip a little if it has difficulty pushing filament through the nozzle for a moment, rather than viciously grinding away at it.
Hi, Filament problems could be caused by inconsistent diametar, you could change the spool and try again. Try to push the filament trough by hand and you should get consistent flow, if not nozzle needs cleaning. You could thy the cold plug method for cleaning. Also try to tighten the part that holds the filament against the hobbed bolt, hope this helps
I would honestly return the spool for that much of a variance in diameter. Double check that your extruder gear is aligned and properly tightened as well! Ps. I run a filament oiler/duster to help reduce the chance of jams and clogs.
I’d agree with the others that the most likely cause of the inconsistencies in feed rates is caused by inconsistent filament diameter. Where the blockage is concerned, it may also be that the filament gets too wide and jams, but I’d also look to heat creep as a possible culprit. You’re printing at a high temperature for PLA and, if the heat sink on your hot end isn’t that great, heat can flow up, cause the filament to expand and you’ll get a jam. From the looks of your hot end, the heat sink doesn’t look that great (compare it with a picture of an E3D from e3d-online).
Ok, for the most part I order abs, haven’t really payed attention to pla on there. They normally keep quite good stock but lately every time they get stock it’s sold before I even get the email notification, guess the word about their quality has started getting out…
I think I misunderstood what you guys mean by twisting. The more a filament sits out in the open air the more it holds it’s curl and gets brittle. Hard to see what’s causing the waviness in the photo, but I suppose I could see my little stock mini kossel extruder struggling to pull that through consistently.
I was talking about where you can’t pull the filament off the spool because it’s tangled up in the other windings; maybe it’s more common on large spools. Once a spool does it to me, it’s a repeating problem. Sometimes it clears with a tug, others it needs more TLC - so I just wind spools onto new ones once this happens, working through all the knots.
Thumbs up on the ESun cleaning filament. I just got some this week (ordered thru Amazon), and manually pushed about an inch worth through each 0.4mm hot end and then just pulled it back out. They were both printing hairlines that would curl up around the nozzle, even after I cleaned the nozzles and the heat break tubes with a blow torch (probably leaving some carbon traces behind.) Apparently PVA can really clog things up. Then after the cleaning filament, they were squeezing out straight 0.4mm extrusions and printing nicely again. I was truly amazed.
I printed a little filter container for the filament, put a small sponge in with a few drops of vegetable oil and closed the lid, there is a small hole to feed the filament through, Besides cutting sections of the poor roll I added this to help ensure less jams. Dont know if it actually helps or not
I had a problem like this and it turned out the hot end thermistor was shorting out. This was causing the hot end to cool and then it would jam. Run it until it starts to jam and then check the temp of the hot end.
I have never had to clean my filament and I print alot. I think jams are generally due to the nozzle being too close to the build platform or incorrect temp.
I’ll suggest some of the various issues that come to mind.
1: Are you using ABS or PLA? - Most PLA filament I know of prints at 190-200c. ABS prints at 230c, so the 205-220 range you listed doesn’t really fit either of them very well. If you’re printing at too high a temp for PLA it might liquefy too soon in the hotend, expanding into areas and jamming the whole operation up. Additionally, pick up a spool of Hatchbox PLA from Amazon. It’s cheap, and known-good plastic to work with.
2: If it came with an “E3D V6” clone, that might be the issue right there. I only have experience with the E3D V6 and it’s important to get the PTFE tube (bowden style or direct drive) seated into the metal heatbreak connector tube. Sometimes you might think it’s in, but it’s not. Thus allowing filament to miss the nozzle hole and jam up.
3: Clean the nozzle and any metal parts with fire! I routinely get the steel heatbreak and brass nozzle up to red-orange temps with a torch for cleaning. Then I’ll drown them in veggie oil to “season” (lubricate) the metal parts before putting it all back together. I’ve also had to lightly push a needle point into the tip of the brass nozzle when something was jamming it up.
4: Get a filament filter. The simplest version is just running the filament through a piece of dish sponge. The one I use encloses the sponge and allows for application of veggie oil periodically.
5: Check out the extruder hobbed gear and clean it. Filament will get worn into the little teeth and reduce your grip. Upgrading to a “Mk8 gear” increased the reliability for me and I can even run it without a gear reduction at moderate print speeds.
Throw that crap out! That much variance is sure to jam your hot-end! After three years of printing, I’ve found it’s more than worth it to buy some good-quality, consistent filament. The few bucks saved on the cheap stuff will only make you pay in all the hassles and horrible print quality.
It seems a filament issue here. less material in the sample photos, alternating with extra in some layers.
Change the filament with a consister diameter one.
I have a Prusa I3 with upgraded e3d v6 and had the same problem with nylon taulman ,what supoused to be accurate, but no, 1.8 mm and more a recurrent jam in the high quality hot end.
Also check if the filament is getting hot before the hot end, so is getting soft and jams. Check the tiny fan who cools down the hot end’s tube.
You should try speed down the printing, really slow (30), and check again.
It was definitely the filament, as I said not only is it inconsistent but it is twisted like a twizzler. I have been taking so many meters off at a time and untwisting and using the piece I have cut to print. However I would say that half the roll is a loos due to the poor quality of it.
