Feb 2016
Definitely looks like a filament issue, its way to off and not even round, 1.95mm will not be possible to pushed into the head so the extruder will grind it or loosing steps. Try to spool down 10-15 meters and measure again if still crap, try to return the filament to the supplier.
Tolerance should be 1.70-1.80 maximum for filaments.
Br.,
Tamas
I would do two things:
- check if extruder gear is not filled with grinded filament that will make it slip
- try a good quality filament since yours looks like a low quality one
I also bought a Chinese brand printer and had problems with hot end jamming from the start. I finally replaced the nozzle with a different brand and everything is fine now. Cost me 8 $ but was totally worth it. Don’t buy cheap extruded nozzles.
I had constant jams on my generic MK8 hotend plus a stripping drive wheel / clicking. I fixed it on mine by adding an oil wipe / vegetable oil drops on the filament while it is printing. This works for both ABS and PLA.
If your hotend is really buggered up, you may have to clean it using acetone first. Also, you may need to put a stronger or weaker spring in your tensioner - the default that came with mine was very weak and allowed the hob to slide.
Finally, double check that your extrusion rate is correct for your stepper / motor. My default setup was pushing slightly too much per turn and would instantly overload the head. Raising your heat a bit might also help, especially when using the oil.
