This sounds to me like a very poor quality filament… If it varies by almost 0.5mm I would demand a refund or throw it out/recycle it.
Definitely looks like a filament issue, its way to off and not even round, 1.95mm will not be possible to pushed into the head so the extruder will grind it or loosing steps. Try to spool down 10-15 meters and measure again if still crap, try to return the filament to the supplier.
Tolerance should be 1.70-1.80 maximum for filaments.
Br.,
Tamas
Hello! I too have a Chinese printer kit, well, actually three… and I must say in the beginning it was rough but man once these things get working are they ever a piece of art! I have to ask, are you printing with Chinese filament? Some filament is actually extremely poor in quality, not just the diameter or shape but the plastic itself. My first printer I bought came with really good filament, but the next two had filament that was better off being burned than trying to extrude it. I also have to ask, as I made this mistake myself, when you cleaned the extruder assembly, did you do so with a torch of some type? I was unaware at the time, but there’s actually a piece of Teflon tubing in the upper threaded part of the extruder assembly and I had actually burned it right out, filament was constantly getting clogged without it and it was a massive pain until I got a new one and realized my mistake.
Also if you live in Canada, depending where you are, I would highly recommend ordering your filament from filaments.ca, they do a great job, I’ve probably ordered upwards of 15kg from them
Ok I cut 2 10 meter sections off the roll. I then spent 5-10 minutes pull the twist out of each section. I was able to get 2 successful prints from both pieces after doing this, so maybe the roll is salvageable
On their website the majority of their pla is sold out
I would do two things:
- check if extruder gear is not filled with grinded filament that will make it slip
- try a good quality filament since yours looks like a low quality one
I also bought a Chinese brand printer and had problems with hot end jamming from the start. I finally replaced the nozzle with a different brand and everything is fine now. Cost me 8 $ but was totally worth it. Don’t buy cheap extruded nozzles.
