Feb 2016
Also if you live in Canada, depending where you are, I would highly recommend ordering your filament from filaments.ca, they do a great job, I’ve probably ordered upwards of 15kg from them
Ok I cut 2 10 meter sections off the roll. I then spent 5-10 minutes pull the twist out of each section. I was able to get 2 successful prints from both pieces after doing this, so maybe the roll is salvageable
I would do two things:
- check if extruder gear is not filled with grinded filament that will make it slip
- try a good quality filament since yours looks like a low quality one
