Feb 2016
While the filament thickness issues are certainly a red flag, I’ll offer a couple more things to check, based on my having the same issues a while back. I mean, you got some successful prints, and then things went bad. Sounds very familiar… I think I’ve actually had all of these problems at the same time before:
1) Check gears on your extruder drive and make sure there is no loose play at all in their movement. If either of the plastic gears turn independently of the other, or of the motor spindle, that’s bad. Even just a mm’s worth. In my case, the plastic at the center of the large gear started wearing out so that it wasn’t locked onto the hex screw holding it in place. So as a print extrudes and retracts, back and forth, it eventually gets to a place where there are so many retractions in a short period of time, that the gears are turning back and forth without actually driving any filament forward. I super glued it together long enough to print a new gear and mount it better (with a bead of super glue from the get-go.)
2) Make sure the hobbed gear is clean – grinding on filament fills the grooves and the teeth don’t grab like they used to.
3) Too high of a retraction distance. I’ve seen advice particularly about keeping the value low for PLA (1.2mm or less, YMMV), as it’s kinda sticky, and if you get too many retractions in a row (most slicing apps have settings for mitigating that situation), it can pull it up into the cold part of your hot-end assembly, cooling the PLA and jamming it up above your hot end.
4) Cross-wound filament. I often re-wind a new spool of filament manually onto another spool, because there are often spots where it’s been wound so tight by the manufacturer that the extruder can’t pull off the spool. Then it just grinds away on that one spot. But that problem would likely have been obvious.
5) A crazy thing I would have never guessed to try – I tried this piece of advice and it seems to be working – reduce the current to your extruder motor when using PLA (and back up again for ABS.) Go into your firmware and find the setting:
#define DIGIPOT_MOTOR_CURRENT {135,135,135,135,135}
and adjust one or both of the last two 135’s (extruder 0 and extruder 1.) “135” represents a value from 0 to 255, where in my Marlin firmware 135 => ~0.75A. I use 85 to have it pull about 0.5A. This will allow the motor to slip a little if it has difficulty pushing filament through the nozzle for a moment, rather than viciously grinding away at it.
Just saw this after posting my reply. I have the cross-wound filament issue consistently with MG Chemicals filament, especially about halfway through the spool. It may not get stuck for good, but can cause gaps like you’ve pictured while it struggles to loosen the knot. I like MakerGeeks’ filament, but I’ve had this problem even with theirs - halfway through the spool.
I would honestly return the spool for that much of a variance in diameter. Double check that your extruder gear is aligned and properly tightened as well! Ps. I run a filament oiler/duster to help reduce the chance of jams and clogs.
I’d agree with the others that the most likely cause of the inconsistencies in feed rates is caused by inconsistent filament diameter. Where the blockage is concerned, it may also be that the filament gets too wide and jams, but I’d also look to heat creep as a possible culprit. You’re printing at a high temperature for PLA and, if the heat sink on your hot end isn’t that great, heat can flow up, cause the filament to expand and you’ll get a jam. From the looks of your hot end, the heat sink doesn’t look that great (compare it with a picture of an E3D from e3d-online).
Ok, for the most part I order abs, haven’t really payed attention to pla on there. They normally keep quite good stock but lately every time they get stock it’s sold before I even get the email notification, guess the word about their quality has started getting out…
I think I misunderstood what you guys mean by twisting. The more a filament sits out in the open air the more it holds it’s curl and gets brittle. Hard to see what’s causing the waviness in the photo, but I suppose I could see my little stock mini kossel extruder struggling to pull that through consistently.
I was talking about where you can’t pull the filament off the spool because it’s tangled up in the other windings; maybe it’s more common on large spools. Once a spool does it to me, it’s a repeating problem. Sometimes it clears with a tug, others it needs more TLC - so I just wind spools onto new ones once this happens, working through all the knots.
