with the attached pictures, you’ll see my problem: bad connection from the support structures to the actual print. The complete print got lost and i found it in the resin as a remaining flat layer crumbled on the bottom of the tank.
I used 0,8 mm (thick) points for the structures, so acutally enough surface for connectivity. I used a completetly new resin (black of formlabs). I had exactly the same issue lately with clear resin.
Do you have any idea?
Potentially, i assume inhomogenities in the resin. But i mixed it well. Also rests of isopropyl might be an answer, but i carefully wash of the base plate, before using it again…
@TheSignStudio: yes, its definitvely not the position. the other picture with two parts on it changed the position of the failed print and it failed there too…
We used to have the same problem with our Form 1. Two out of three prints were a fail and the results we had were similar to what I can see in your pictures.
The problem went away after we sent the print to be upgraded. The upgrade also includes a recalibration and that is where I suspect the problem lies. Try looking through the calibration information on their website, they also have an interesting video tutorial that I cannot find right now.
I have had this same problem as well. I was printing a larger piece and it got through 75 percent and the rest was on the bottom of tray. I added more supports and it printed perfect after that. Hope this helps. Good luck!
All the comments are great. Orient the part so the longest diagonal through the part is nearly perpendicular to the build platform. Place the tallest portion of the print closest to the hinge. View the layers and try and orient the part so that no section volumes are closed. Closed volumes cause suction that can punch holes in walls and cause prints to fail. If you must have closed volumes try and minimize the projected area of them and/or add a vent hole or split the part to eliminate them. Orient the part so that a volume closes last. In other words If you have a cup shape print it open end towards the build platform.
One additional thing about vent holes is that they need to be rather large. I had a couple prints fail on me with a 2mm diameter vent hole, the resin is just too thick to freely float trough a 2mm hole. I’m now making vent holes at least 4mm diameter and haven’t had a problem with them.
Also, if you have prints failing like this, check the tank bottom for clouding - if it’s clouded you can throw away the tank
From what I have gathered from the responses here, and your research, you should probably have some successful prints already.
One thing I have noticed is that sometimes I see print failures when, during the Form 1/1+ printing process, there was a significant temperature change.
I try to print during the day when temperatures can be held more constant, warmer than cooler.
Also, as Im sir you have read already, keep those internal mirrors very clear (minimal dust). I have had issues with resin tanks, both the hard plastic and the PDMS layer, being distorted that caused some really strange failures.
Occasionally, I have to set time aside to think deeply about the motion of the peeling process and how it relates to the support structures and part orientation.
It seems like, if you can, keep as much of the part as continuous layers, not contiguous, as I have seen some distortion there too. There is a lot to learn about how to get these Form 1/1+ printers to produce magically good parts. We are all learning, even the crew at FormLabs is learning about this “tech-magical” (not a real word) process. Good luck!
I almost forgot to add, orient your parts at angle, if possible, to the bold platform.
Several planar/prismatic formed parts seem to distort if planer surface features are oriented parallel to the build surface.
I have seen this distortion ion parts during the print process and post curing too.
My experience with the Objet printers output seems to follow this “warping” distortion as well, especially when parts are left in the sun for long periods of time.
Hey Guys, Thank you very much for your advice! I just started a new print considering you suggestions. I’ll give you an update tomorrow as soon as the print finishes.
Thanks for your insight. At least the temperature thing i can rule out, since we monitor this tediously. Even FDM printers are really sensitive to temperature cahnges.
-Scroll through the layers in preform, do they all look right? Sometimes bad STL’s can cause Preform to show the model, but it doesn’t slice it properly
Well, the fact that the supports print so nice and you used a new tank and different resin at least tells you there is nothing wrong with the printer.
If you don’t find the problem and you can’t upload the model, post a screenshot of the cross section (layer) where the printing of the model starts failing.
PS: you shouldn’t place models on the build platform like that - even if they print, the strain on the mechanics and tank will be much higher than with supports.
The reason I printed the cube directly on the bed was that the removement of the support is quite tedious and i had to ship 50 pcs, I considered this a good idea (spoiler all cubes where fine). Additionally the support generated would be consume as much resin as the cube itself.
Which raises another general question to me, since 3D Hubs cant calculate the volume of the needed support how do you the pricing? simply assuming some percentage offset, hoping it doesn’t need more? I already have trouble, due to failures of such a simple looking model
But anyway thanks for the hint on the strain! could you please add more detail to you explanation? since i can’t imagine why there should be less strain if printing with supports and the same orientation. it has to peel it off anyway?
-I always add costs for support to orders. Haven’t had a customer reject his order because of the added cost. I agree that this should be fixed or at least there should be a way to inform the customer that there will be added cost. The other option is to jack up your ml price but that doesn’t help if the customer compares prices.
-Supports help take some strain off the peeling process because they allow the platform-part-tank to move in x/y a bit, so they take the initial hit before the part peels of the tank - otherwise these forces will work against the peeling mechanism, your platform and the tank / PDMS layer. If you watch it print a larger cross section you may notice that your platform slightly tilts on peeling, together with the tank - when you print directly on the platform, the platform and the tank are basically glued together and nothing can move in x or y - but it wants to shift a bit, and that force now goes to the T-rail, tank and platform (and your print)
Also when placing objects flat on the tray, you usually printing the largest cross section through the whole print (the cube is an exception obviously)
I also tried to print objects directly on the platform, cause I wanted to save resin and have nice surfaces, but out of 3 different parts, only one printed right.
Lastly, Formlabs themselves state that you should always use supports - although one might argue this is because they like to sell the juice for those supports
For me, the thinking goes like that: A failed print means wasted juice, wasted time cause I have to filter the resin, potentially a wasted tank because of clouding and I have to start all over with the print. If I can avoid one failed print in 20 by placing supports, it’s worth it to me - especially cause I make the customer pay for the supports.
On another note, place objects near the hinge side of the tank to reduce the strain on the peeling stepper / threaded rod. You will have more lever -> less force needed.
The only other suggestion I have that I have not seen made is to increase the density of supports. I have had some models that just take more supports than others to print properly. And yes you will use more resin for supports however you have at least 2 failed prints that uses resin too. You might want to empty the tank and filter the resin before refilling. Cleaning the tank and filtering the resin is always a good idea after any failed print. Use a funnel with a pipe filter screen or a paint filter. Floaters in the resin can really cause lots of troubles. They do not always affect the base because they are squished out to the edges. As the part builds they are drawn back into the center where they block the resin from curing to the already built part and or supports. Once you get any gap at all the part degrades and can fail completely.
I have a question about what I see in the current images showing a completes print.
What is the Orange tape for? I’ve never used that before. If anything, my parts always seem very difficult to remov from the bare aluminum build platform.
Maybe its a bit confusing, sorry for that the second picture shows the print curing on a metal plate, which is a heated bed from a RepRap Mendel design of us and has nothing to do with the Form1 we just placed the part there. The orange tape is Kapton tape. It is used with FDM printers to get a better adhesion to the bed.
