I have a question about what I see in the current images showing a completes print.
What is the Orange tape for? I’ve never used that before. If anything, my parts always seem very difficult to remov from the bare aluminum build platform.
Maybe its a bit confusing, sorry for that the second picture shows the print curing on a metal plate, which is a heated bed from a RepRap Mendel design of us and has nothing to do with the Form1 we just placed the part there. The orange tape is Kapton tape. It is used with FDM printers to get a better adhesion to the bed.
