I have had this same problem as well. I was printing a larger piece and it got through 75 percent and the rest was on the bottom of tray. I added more supports and it printed perfect after that. Hope this helps. Good luck!
All the comments are great. Orient the part so the longest diagonal through the part is nearly perpendicular to the build platform. Place the tallest portion of the print closest to the hinge. View the layers and try and orient the part so that no section volumes are closed. Closed volumes cause suction that can punch holes in walls and cause prints to fail. If you must have closed volumes try and minimize the projected area of them and/or add a vent hole or split the part to eliminate them. Orient the part so that a volume closes last. In other words If you have a cup shape print it open end towards the build platform.
The reason I printed the cube directly on the bed was that the removement of the support is quite tedious and i had to ship 50 pcs, I considered this a good idea (spoiler all cubes where fine). Additionally the support generated would be consume as much resin as the cube itself.
Which raises another general question to me, since 3D Hubs cant calculate the volume of the needed support how do you the pricing? simply assuming some percentage offset, hoping it doesn’t need more? I already have trouble, due to failures of such a simple looking model
But anyway thanks for the hint on the strain! could you please add more detail to you explanation? since i can’t imagine why there should be less strain if printing with supports and the same orientation. it has to peel it off anyway?
-I always add costs for support to orders. Haven’t had a customer reject his order because of the added cost. I agree that this should be fixed or at least there should be a way to inform the customer that there will be added cost. The other option is to jack up your ml price but that doesn’t help if the customer compares prices.
-Supports help take some strain off the peeling process because they allow the platform-part-tank to move in x/y a bit, so they take the initial hit before the part peels of the tank - otherwise these forces will work against the peeling mechanism, your platform and the tank / PDMS layer. If you watch it print a larger cross section you may notice that your platform slightly tilts on peeling, together with the tank - when you print directly on the platform, the platform and the tank are basically glued together and nothing can move in x or y - but it wants to shift a bit, and that force now goes to the T-rail, tank and platform (and your print)
Also when placing objects flat on the tray, you usually printing the largest cross section through the whole print (the cube is an exception obviously)
I also tried to print objects directly on the platform, cause I wanted to save resin and have nice surfaces, but out of 3 different parts, only one printed right.
Lastly, Formlabs themselves state that you should always use supports - although one might argue this is because they like to sell the juice for those supports
For me, the thinking goes like that: A failed print means wasted juice, wasted time cause I have to filter the resin, potentially a wasted tank because of clouding and I have to start all over with the print. If I can avoid one failed print in 20 by placing supports, it’s worth it to me - especially cause I make the customer pay for the supports.
On another note, place objects near the hinge side of the tank to reduce the strain on the peeling stepper / threaded rod. You will have more lever -> less force needed.
Thank you very much @Tobias_4!! your comment is really valuable, thanks for sharing.
You are most welcome! Let us know if and how you resolved this.
Tobias
I have a question about what I see in the current images showing a completes print.
What is the Orange tape for? I’ve never used that before. If anything, my parts always seem very difficult to remov from the bare aluminum build platform.
Maybe its a bit confusing, sorry for that the second picture shows the print curing on a metal plate, which is a heated bed from a RepRap Mendel design of us and has nothing to do with the Form1 we just placed the part there. The orange tape is Kapton tape. It is used with FDM printers to get a better adhesion to the bed.
What did you change?
