Sep 2015
Hi, I’m also looking for this, I got a heat nozzle set from ebay but the filament hole is too thin when compared to the one that comes with the printer - the original Teflon tube won’t fit.
I did find teflon tube for sale on ebay as well, but not the matching heat nozzle for the CTC 3D.
Also, the throats listed aren’t the same as the ones in the printer (i.e. smooth cylinder shaped) - the ones on show are mostly screw-types.
Any help on this would be great, thanks!
Hi Russell.
I have some spares including:
1) hot end M6 threaded tube with heat break. I do have some smooth ones too.
2) aluminium block for heater and thermocouple
3) glass fibre insulation for the heated block
4) 0.4mm brass hot extruder end
i don’t have any of the Teflon tubing that goes into the M6 threaded or smooth tube.
you can buy these parts in bulk from Aliexpress or eBay. That’s where I originally bought them from.
best regards
myles
Not without extensive modification. You will need either a genuine menu rep 1 dual cooling bar or a Carl raffle dual bar. Carl’s cooling bar needs the aluminum z carriage also as is wider. Carl’s carriage also needs a closed loop x axis belt.
Hi Russell. I’m in the UK and can sell you the parts you need.
I can send some pics of what I’ve got and you can see whether they are what you need.
best regards.
Myles
yes please and also what do I need to rap around the heater blocks ive got kapton tape
Hi russell. I’ve got the fibre that is meant for this. Will take a pic later today and send. Rgds m
