Sep 2015
I ended up buying spare nozzles on ebay, for the MK9 as I have a CTC 3D:
http://www.ebay.co.uk/itm/201311328257?\_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The nozzle that came in isn’t even the same size as the ones that came with the printer: not as wide and the filament hole is too thin as well.
Did another buy for these: http://www.ebay.co.uk/itm/321796094101?\_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
From the pictures, these seem like the same model, but I’ll let you know once they arrive.
Also, decided to get some PTFE tube http://www.ebay.co.uk/itm/111513375750?\_trksid=p2057872.m2749.l2649&var=410506092329&ssPageName=STRK%3AMEBIDX%3AIT
Once I have everything I’ll let you know how these compare to the original installed parts.
Yes they should work on a ctc machine as they work on the replicator 1 and they fit the flashforge mk9 machines and it means you can use mk10 nozzles which are better don’t know how but bigger number = better
