Sep 2015
yes please and also what do I need to rap around the heater blocks ive got kapton tape
Hi russell. I’ve got the fibre that is meant for this. Will take a pic later today and send. Rgds m
Hi Russell. Please see attached. The ctc bar with hot-end has been used. So has the other hot-end. I can dismantle and sort for you if you need them.
All other parts are new. There are several new:
a4982 bot-steps
hot end blocks
threaded filament tubes
brass extruder ends
hot-end insulation
mechanical endstops
20t gear for x or y axis
I’ve also got a couple of 24v extruder fans and spare parts for the extruder carriage.
i have most of these as spares or leftovers from upgrading the extruder carriage and ends with the Carl raffle upgrades.
thanks. Myles
Hi Russell. Parts are for sale. I need to work out a price for you. I’m away at a trade show tomorrow, but hopefully will get a price to you tomorrow evening if that’s ok. I think the most expensive parts are the botsteps, everything else is quite cheap. Best regards Myles
I’m not to worried about the electronics buddy its the other bits I need at the moment
thanks bud
I ended up buying spare nozzles on ebay, for the MK9 as I have a CTC 3D:
http://www.ebay.co.uk/itm/201311328257?\_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The nozzle that came in isn’t even the same size as the ones that came with the printer: not as wide and the filament hole is too thin as well.
Did another buy for these: http://www.ebay.co.uk/itm/321796094101?\_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
From the pictures, these seem like the same model, but I’ll let you know once they arrive.
Also, decided to get some PTFE tube http://www.ebay.co.uk/itm/111513375750?\_trksid=p2057872.m2749.l2649&var=410506092329&ssPageName=STRK%3AMEBIDX%3AIT
Once I have everything I’ll let you know how these compare to the original installed parts.
Yes they should work on a ctc machine as they work on the replicator 1 and they fit the flashforge mk9 machines and it means you can use mk10 nozzles which are better don’t know how but bigger number = better
