Hi, I’m also looking for this, I got a heat nozzle set from ebay but the filament hole is too thin when compared to the one that comes with the printer - the original Teflon tube won’t fit.
I did find teflon tube for sale on ebay as well, but not the matching heat nozzle for the CTC 3D.
Also, the throats listed aren’t the same as the ones in the printer (i.e. smooth cylinder shaped) - the ones on show are mostly screw-types.
Try uncle Chuck. He’s active on the Google groups, gives excellent service. Chuck is retired marine, located in the southwest U.S. started http://www.unclechucks3dprinterstuff.com 2 Your looking for mk9 stuff for the ctc.
Hi Russell. Parts are for sale. I need to work out a price for you. I’m away at a trade show tomorrow, but hopefully will get a price to you tomorrow evening if that’s ok. I think the most expensive parts are the botsteps, everything else is quite cheap. Best regards Myles
Yes they should work on a ctc machine as they work on the replicator 1 and they fit the flashforge mk9 machines and it means you can use mk10 nozzles which are better don’t know how but bigger number = better
