I’m withdrawing my entries. See comment bellow to know why.
I don’t have one design… but THREE
The famous A-Wing that destroyed the Super Destroyer in Return of The Jedi:
https://www.youmagine.com/designs/a-wing-from-star-wars
Anakin and Luke Skywalker Lightsaber… with internal parts!. Build you own lightsaber like a true Jedi:
https://www.youmagine.com/designs/anakin-luke-skywalker-lightsaber
Life-Size Boba Fett’s EE3 Carabine. Chase the rebel scum with this powerful rifle (perfect for cosplay):
https://www.youmagine.com/designs/boba-fett-s-ee3-carbine-from-star-wars
So so so so so soooooo cool! Do you think it would be possible to make it a little bit bigger without changing the electronics?
Yep it would work without any problems.
Maybe the hole for the ultrasonic sensor could be too much large after scaling (not an hard problem to solve).
Hi everyone !
Here is my design entry for the contest : let me introduce to you guys Gasgano’s racing pod ! (seen in Star Wars Ep1 Pod Race Lap 2 (Deleted Scene), and also in the N64 Star Wars Episode 1 : Racer)
Because pod racers are so cool and crazy
I removed original strings because they looked ugly, and replaced them with filament chutes. Looks much better and way more solid.
It would probably have looked way better and detailed if printed bigger (I printed it 5% scale).
STL file attached.
Hope you like it, enjoy and good luck to everyone =)
Cheeeeeeers
gasgano-s_racing_pod_fixed.stl (9.49 MB)
I’d like to participate with my Jedi Holocron Cube, one of my favorite Star Wars related items. It was designed to be very easy to print, no support/rafts/etc, while allowing for a lot of customization regarding post-printing finishing options. Inside is a 1"x1"x1" space for adding lighting effects. In the photo I printed the internal cube in transparent PTEG, and the side panels in white ABS. After printing the side panels were spray painted with 24k gold acrylic. 3 side panels are attached to each half of the internal cube. Everything was printed at 200 micron, the internal cube was printed with 0% infill, and the side panels 100% infill, and It took about 12 hours. It was designed to take advantage of a 3D printers ability to repeatably make complex object, print in place small push fit pins, and print objects that contain internal voids for electronics.
You can download the files to print the Jedi Holocron Cube, at the following link.
Mo3D
80
Here is the screen accurate Cosplay prop of the Storm Trooper Officer Pistol (SE-44C) I designed and printed. I originally designed this for the 501st Legion but decided I’d also enter it into the competition!
There are to many parts to just upload them to the post so here is the link! I’ve attached an image showing my print next to the actual screen prop picture.
Dont forget to follow me on facebook and instagram if you like what i do
Facebook: Redirecting...
Instagram: @mo3d.printing
I do see an issue with people entering a tonne of previously made designs, as it gives newer designers little chance to compete.
If I had created the comp (I wish…) it would have been the following criteria:
1. The model must be created for the comp (otherwise we’ve seen it all anyway - if you are into 3D printing chances are all of these are not new)
2. Only 1 entry per person.
3. Winner decided soley by 3DHubs and not how many friends you can get to come and upvote you.
Good to see they got 1 out of 3 right so far. Here’s hoping for the next comp.
hi everyone just got my prints back from a very kind friend of a friend with a printer so here are my luke and vader mini figures I’m entering for this contest that I designed on tinkercad. this is link
https://www.youmagine.com/designs/star-wars-luke-and-vader
yoda3d
83
Hello,
I would like to enter the competition with this model:https://www.youmagine.com/designs/head-of-yoda-a95a8e4a-146e-41c5-978e-c1c1c217fbed
Head of yoda that I modeled and printed .
I wanted to make a model that is detailed but easily printable.
Printed without support.
May the force be with you:)
yodaprint.stl (24.4 MB)
yoda3d
84
Hello,
can we present several models?
- YouTube My last update about the project
One of my favourite Star wars characters is Count Dooku, especially the Clone Wars version, and I have been wanting to sculpt one for a while now, so here it goes. It was 3d sculpted using ZBrush and 3d printed on a Zortrax m200, then Hand painted using Vallejo paints!
The project was supposed to be a study after the original sculpt of Darren E. Marshall a challenge to see if I can make it look as close as possible to the original and a huge desire to have that sculpt in my office, I ended up learning so much from this project.
Make sure to check out my Blog for the entire project walkthrough
http://www.pixelophy.com/2016/03/count-dooku-study-sculpt-and-3d-print/
Merged_Dooku_120mm.stl (69.7 MB)
Daam
87
Hi, I finally printed my design for this competition, I did a little Ewok head to support my Wacom pen, you can also find a version without the hole so you can modify it the way you want.
Here’s the link to youmagine : https://www.youmagine.com/designs/ewok-head
ewok.stl (29 MB)
ewok_wacom.stl (20.5 MB)
Hi guy’s!
My entering for the competition is a designed by myself lightsaber. I wanted to do something different for this competition since it is my dream to one day work or participate in a star wars movie or project. The lightsaber consist of six printed parts and takes a total of four hours.
Design is my passion, with this idea in mind I’ve designed a lightsaber thats easy to print and very easy to assemble. So if you like it give me a thumbs up and the force will be forever in your favor!
The following link leads to the YouMagine page:
https://www.youmagine.com/designs/lightsabre
May the force be with you, always
deel1.stl (67.7 KB)
deel2.stl (45.4 KB)
deel3.stl (78.3 KB)
deel4.stl (40.3 KB)
deel5.stl (22.7 KB)
kern.stl (14.1 KB)
Looks great!
Although… if your Zortrax is gathering dust I don’t think you need a new Ultimaker
Thanks!
Do you think the sole reason to enter a competition is to win? I’m here to learn, share my experience, meet new people, promote my blog, promote my hub and I can go on… and when I wrote that my “Zortrax was gathering a bit of dust” I was trying to prove a point, maybe I was to subtle (I’ll try better next time). I really hope you entered the contest and I really hope you win the Ultimaker this way you can stop worrying about people having too many 3d printers in the shop!
That looks awesome! Are you thinking about post-processing/painting it as well?
Lol it was just a joke. Who knows, you might have needed some more filament too
ill enter at some point, I was just trying to make something specifically for the competition rather than using an old model.
I created this 3D Printed BB-8 droid!
It is motorized and remote-controlled to move around and interact.
I’ve made the design in SketchUp, It’s printed half-size so it doesn’t take tons of filament. The robotic platform is Arduino-based so you can add programmable LEDs and sounds.
The video is here: https://www.youtube.com/watch?v=ONnFEvNyB_g
Enjoy!
