Mar 2015
Hey all,
We have begun with the certification for the Lock Nester puzzles. This is our most challenging printing collaboration so far. Attached in the .zip file you can find a manual with recommended settings for printing the puzzle piggy. For any additional questions and tips, you can post on this thread.
Good luck!
Lock Nester - Monica Manual.pdf (5.63 MB)
    Oct '14
    Sep '15
  • 46
  • 2.7k
  • 30
Hi @Luuk, my hub is located in London and I would like to get my hub certified for the Lock Nester puzzles. How do I go about getting the STL zipped files? Many thanks. Have a good weekend!
Hi, when I use the settings in the manual I get a lot of support material (print time 4,5 - 5 hours) for each file. In your manual I see examples of almost no support material, in the manual there is also stated that each lock-nester model comes with custom designed supports.
Do you have tips/ tricks for better support stucture settings.
I’m using Cura
Maikel
I had an issue with Cura too. If you set the minimum support angle too high you will get lots of support material as you’ve described. If you set it lower I found that some required supports dissapeared altogether. There are a few settings you can play around with (x,y and Z clearances for support), but I came to the conclusion that Cura has bugs with creating supports (and this was backed up on some of the forums I searched) I ended up creating support manually in meshmixer and then exporting and generating the gcode in Cura.
Just my experience bu I hope it helps you!
Regards,
Greg
Z-Axis 3D
Sorry, to clarify the setting is in Expert settings and its called “Overhang Angle for support”, the default is 60.
I stated it the wrong way round in my original post. Making this angle LOWER ADDS support of course, and HIGHERr REDUCES support.
Hi @fleethower,
I was asked by Luuk to get in touch regarding a problem I’m facing with the certification print of Monica. The printing seemed to work fine with good quality, but when completed and after minimal processing and removal of the flashing and support it seems the model does not stay together. I’ve been very carefull not to remove to much material, but still Monica falls appart. Do you have any tips/sugestions to overcome this issue…
Thanks,
Martin
Hi Marinv77, the print quality looks good. That piece can be a bit loose, but they should hold together. I’m wondering if you haven’t smoothed the connections enough where the supports were. I’ve run into problems when not sanding enough, but have never run into any problems by sanding too much, try smoothing those areas a bit more. Let me know if that helps, this looks like an ultimaker, correct?
Hi Greg and Maikel, you should have recently received a file with the supports already included, so that you won’t have to generate any in cura. This should make the printing go more smoothly, please let me know if you haven’t received that file.
Thanks!
Hey Martin, great, I’m glad to hear it. Your print quality looks fantastic, thanks for being a part of this project!
I had this problem as well, although it was not due to sanding. My problem is that the head piece was much too loose, causing it to fall off unless the whole piece or orientated upwards.
There is one more trick you could use, but be carefull as it can potentialy ruin your print.
Try holding the lips of the head piece under hot watter and gently squezze them together so the get a fraction of a milimeter tighter. This gave the final result for me.
Again, be carefull
Martin
Hi all.
here is my result of Lock Nesters Monica.
Printed in faberdashery “cherryblossom pink” and ColorFabb “fluorescent pink” :slight_smile:
btw: After earning the badge, how do we get the other Lock Nester Models for test prints?
The certification model is just Monica, she is the toughest print to make. Once certified you will receive the final models around October 20 or 21, but test prints for those models should not be necessary unless you would like to conduct them on your own.
Best,
Fleet
Hi Ara, thanks for your interest and testing! We have been furiously trying to finish all the models and have just done so. The tail modification is a great idea, will look into that asap and see if new files can be distributed to the hubs.
Thanks!
Hey Tiguu3D,
I will look into whether you’re eligible to participate in this program a.s.a.p. You will hear from me soon.
Same question as Tiguu3D, i would like to add the badge to my Hub, it’s located in Belgium.
Regards,
Didier Klein
8 days later
Hi Luuk,
Can I join the program too? Can’t find the zipfile btw you are referring to in this post. Btw I can’t wait to print George, with a whopping amount of 185 pieces…
Merijn
Hey Merijn,
you got your certification order. Good luck!
12 days later
HelloI’m from Germanydo you have a test puzzle for me ?I’m from Germanydo you have a test puzzle for me ??I’m from Germany,do you have a test puzzle for me ??Hello Luuk,
i´m from germany,
do you have a test puzzle for me???
greeting
frank
Hi Luuk,
I am interested in the Lock Nester Certification. Can yoy kindly send me an order?
Thank you in advance for your attention.
Best Regards
Helder
Hello Luuk,
I am interrested by the certification to. Can you send me the certification order please?
Thank you.
Best regards,
Elvis
10 days later
Hi Luuk,
Can you send me the certification order please for the Lock Nesters?
Orlando
29 days later
Hi Luuk,
Best Regards
Helder
Hi Luuk,
I am interested in the Lock Nester Practices. Is it possible to send me a certification order ?
Thanks
Wim
