Hi Marinv77, the print quality looks good. That piece can be a bit loose, but they should hold together. I’m wondering if you haven’t smoothed the connections enough where the supports were. I’ve run into problems when not sanding enough, but have never run into any problems by sanding too much, try smoothing those areas a bit more. Let me know if that helps, this looks like an ultimaker, correct?
Hi Greg and Maikel, you should have recently received a file with the supports already included, so that you won’t have to generate any in cura. This should make the printing go more smoothly, please let me know if you haven’t received that file.
Thanks!
Yes indeed Ultimaker 2…
I will try sanding a little more than and see what that brings.
Thanks
Martin
Hey Martin, great, I’m glad to hear it. Your print quality looks fantastic, thanks for being a part of this project!
I had this problem as well, although it was not due to sanding. My problem is that the head piece was much too loose, causing it to fall off unless the whole piece or orientated upwards.
There is one more trick you could use, but be carefull as it can potentialy ruin your print.
Try holding the lips of the head piece under hot watter and gently squezze them together so the get a fraction of a milimeter tighter. This gave the final result for me.
Again, be carefull
Martin
The certification model is just Monica, she is the toughest print to make. Once certified you will receive the final models around October 20 or 21, but test prints for those models should not be necessary unless you would like to conduct them on your own.
Best,
Fleet
I woudl like to give it a try with this certification, how can I find the files?
Thanks!
Hi Fleet,
thanks for your reply. Sure test prints may not be necessary, but I like it to practice (print and post processing) to be prepared when an official order is placed.
Besides that, collecting all and take a photo of the entire “family” would be fun too
Joerg
Hi Joerg, sounds good, we’re working on the models furiously to get them all finalized, if it’s possible to distribute we will absolutely do so.
Thanks for you interest and help with this project!
Fleet
Quite a few people asked about the certification .stl files. So how/where can they be downloaded?
Thanks,
Stefan
Thats great idea!
I would also like to get certified for Lock Nester.
How can i get in the certification process and get the .stl file for Monica?
Hello everyone, @fleethower,
I have printed six Monicas and gave them to my kids to play with for “market research” (ages 9 and 11). The tail keeps breaking off so I would like to propose making the tail removable. It could also have a long and wide base inserted in a hole. Also, the coli should be thicker diameter. So, is it possible to get the CAD file to make the modifcation? In addition, maybe the tail could be customized to different shapes or be the kids name in script font.
Thank you,
Ara
Hi Ara, thanks for your interest and testing! We have been furiously trying to finish all the models and have just done so. The tail modification is a great idea, will look into that asap and see if new files can be distributed to the hubs.
Thanks!
How do I get certification?
Hey Tiguu3D,
I will look into whether you’re eligible to participate in this program a.s.a.p. You will hear from me soon.
Same question as Tiguu3D, i would like to add the badge to my Hub, it’s located in Belgium.
Regards,
Didier Klein
Hi Luuk,
Can I join the program too? Can’t find the zipfile btw you are referring to in this post. Btw I can’t wait to print George, with a whopping amount of 185 pieces…
Merijn
Hey Merijn,
you got your certification order. Good luck!
Hey Didier,
HelloI’m from Germanydo you have a test puzzle for me ?I’m from Germanydo you have a test puzzle for me ??I’m from Germany,do you have a test puzzle for me ??Hello Luuk,
i´m from germany,
do you have a test puzzle for me???
greeting
frank
Hi Luuk,
I am interested in the Lock Nester Certification. Can yoy kindly send me an order?
Thank you in advance for your attention.
Best Regards
Helder
Hello Luuk,
I am interrested by the certification to. Can you send me the certification order please?
Thank you.
Best regards,
Elvis
Hi Luuk,
Can you send me the certification order please for the Lock Nesters?
Orlando
Hi Luuk,
Best Regards
Helder
Hi Luuk,
I am interested in the Lock Nester Practices. Is it possible to send me a certification order ?
Thanks
Wim
Hi @Luuk
I’m interested to be part of Lock Nesters production in Switzerland.
Do not hesitate to send me the certification order to Gloomy Spark
