Hi Marinv77, the print quality looks good. That piece can be a bit loose, but they should hold together. I’m wondering if you haven’t smoothed the connections enough where the supports were. I’ve run into problems when not sanding enough, but have never run into any problems by sanding too much, try smoothing those areas a bit more. Let me know if that helps, this looks like an ultimaker, correct?
Hi Greg and Maikel, you should have recently received a file with the supports already included, so that you won’t have to generate any in cura. This should make the printing go more smoothly, please let me know if you haven’t received that file.
Thanks!
Hi Fleet,
thanks for your reply. Sure test prints may not be necessary, but I like it to practice (print and post processing) to be prepared when an official order is placed.
Besides that, collecting all and take a photo of the entire “family” would be fun too
Joerg
Hi Joerg, sounds good, we’re working on the models furiously to get them all finalized, if it’s possible to distribute we will absolutely do so.
Thanks for you interest and help with this project!
Fleet
Quite a few people asked about the certification .stl files. So how/where can they be downloaded?
Thanks,
Stefan
Thats great idea!
I would also like to get certified for Lock Nester.
How can i get in the certification process and get the .stl file for Monica?
Hello everyone, @fleethower,
I have printed six Monicas and gave them to my kids to play with for “market research” (ages 9 and 11). The tail keeps breaking off so I would like to propose making the tail removable. It could also have a long and wide base inserted in a hole. Also, the coli should be thicker diameter. So, is it possible to get the CAD file to make the modifcation? In addition, maybe the tail could be customized to different shapes or be the kids name in script font.
Thank you,
Ara
Hi Ara, thanks for your interest and testing! We have been furiously trying to finish all the models and have just done so. The tail modification is a great idea, will look into that asap and see if new files can be distributed to the hubs.
Thanks!
How do I get certification?
Hey Tiguu3D,
I will look into whether you’re eligible to participate in this program a.s.a.p. You will hear from me soon.
Same question as Tiguu3D, i would like to add the badge to my Hub, it’s located in Belgium.
Regards,
Didier Klein
