Oct 2014
I had this problem as well, although it was not due to sanding. My problem is that the head piece was much too loose, causing it to fall off unless the whole piece or orientated upwards.
There is one more trick you could use, but be carefull as it can potentialy ruin your print.
Try holding the lips of the head piece under hot watter and gently squezze them together so the get a fraction of a milimeter tighter. This gave the final result for me.
Again, be carefull
Martin
Hi all.
here is my result of Lock Nesters Monica.
Printed in faberdashery “cherryblossom pink” and ColorFabb “fluorescent pink” :slight_smile:
btw: After earning the badge, how do we get the other Lock Nester Models for test prints?
The certification model is just Monica, she is the toughest print to make. Once certified you will receive the final models around October 20 or 21, but test prints for those models should not be necessary unless you would like to conduct them on your own.
Best,
Fleet
I woudl like to give it a try with this certification, how can I find the files?
Thanks!
Hi Fleet,
thanks for your reply. Sure test prints may not be necessary, but I like it to practice (print and post processing) to be prepared when an official order is placed.
Besides that, collecting all and take a photo of the entire “family” would be fun too :wink:
Joerg
