I guess this isn’t that hard to sort out, get yourself the borosilicate glass plate and a glass cutter from your local diy shop. clamp the glass to the surface with bulldog clips, I like to call them purses, try finding them on the allmighty internet. for a glass plate it takes some time to be completely warm so grab yourself a cup of coffee while warming your printer. hope it helps. kind regards JohnKo
We created a set especially for this, that includes:
- glass plate in correct size (normal glass, 2mm think)
- clips to attach the glass on the plate (without having the nozzle slamming into them)
- z-axis ridge for the Creator Pro that creates an offset for the endstop since the printbed is a bit higher
- spray to attach on the glass for better adhesion
- special designed hood that enables spraying the glass when its on the printbed (without spraying the whole inside of the printer). This saves time to level the buildplate every time after removing the glass.
If you’re interested, I can give you a price offer for the complete kit…
When printing on glass (works very well for ABS!) keep in mind that you preheat your buildplate longer, it takes time before the glass is on temperature.
I simply bought a cheap 4mm glass plate cut to size for £1.50. Printed a Z-axis part to trigger the micro switch 4mm earlier. Leveled the build plate and job done. I’ve actually coated my build plate in kapton tape. Prints simply ping off as the plate cools.
I currently have a Flashforge Creator X (same platform as your Creator Pro) and the Flashforge Dreamer.
I used to struggle a whole lot with bed adhesion and kapton tape used to be my best option but I hated the process of installing it without bubbles or even wrinkles.
Until I invested on a glass plate.
I went to a local picture frame shop and got them to cut for me several sheets of 9" x 6" glasses of of approximately 2mm thick. It was the single best investment I have ever had!!!
My advise is not to buy just glass sheets, but instead, mirrors. It provides added ability to see the heated nozzles through the reflection and helps in the cleaning process. I also found mirrors extremely useful when disassembling the nozzle parts for cleaning.
Do you need the expensive borosilicate glasses you mentioned? Absolutely NOT! Most glasses at 2mm will be great in terms of heat transference and it is very cheap. If you can’t find a shop that can help you cut to size, you can use those glasses that comes in small picture frames. Look for one that is almost A4 size and it should do.
Lastly, I have found incredible success with printing on glass beds using the following combinations:
1) ABS… Just spray any hard hairspray on the glass. No need for Kapton tape or Blue Painter’s Tape. I prefer this to glue sticks as it is not as messy. BEst part is when you leave the glass plates after a print job to cool, the built models will automatically “POP” out hence you don’t need to scrap them from the glass and risk breaking them. I have a few sheets made hence I just remove them from the hotplate and leave it on a cool floor to cool down and place a new glass sheet on the hotbed. Don’t do Blue Painters tape as I find the models warping upwards at the edges hence deforming your models.
2) PLA… for PLA, I have found Blue Painter’s Tape to be best. It does not stick as well to hairspray but sticks like crazy to this tape.
I switched to glass and never looked back. Its really simple too. I use your average standard window glass (although David’s idea of using mirror glass glass is awesome).
I have had no issues with standard glass, despite everyone recommending borosilicate. The glass is cut to the same dimensions as the HBP and use ordinary office clips to hold it in place. For adhesion I use slurry for ABS and ordinary glue stick for PLA.
So I don’t need specialist glass, just anything 2mm thick. Brilliant.
You all talk about the prints popping off when cool, but I’m mostly printing PLA without heating the bed. Glass still a good idea? I’m trying to do away with the painter’s tape…
I use standard (in the US) 8x10 plate glass windowpanes, which are cheap and easy. With 8x10 Plate Glass Clips by laird - Thingiverse 52 to hold them to the print bed. They work great, and it’s easy to swap them when you change Kapton tape vs Painter’s tape vs hairspray, etc.
I recommend trying hair spray instead. I rate it highly because it is incredibly easy to apply (just spray on) and a bottle will last you ages. With slurry ABS, it takes time to prepare and can be messy at times.
99 cent store picture frame for me. 4x6, in side by side portrait orientation results in a glass sheet just about 9 inches long.
I’ve had best luck with glue stick, which for me sticks stronger than hairspray so you lose fewer large prints. I also use a car windshield cleaner that targets bug splatter to clean the glue afterwards; it cleans gluestick better than hairspray.
You can certainly use glass, I prefer using 6 inch wide tape to avoid lines and avoid glue / hairspray. I suppose its all personal preference. I don’t like the “clips” people use to attach a sheet of glass to the build plate though, I’ve got a purpose built solution on the way, let me know if you’re interested.
Feel free to use code EAF9B700D3B4E18 on my site for 10% off at checkout. I’ve got some great 6 inch tape, both standard and high temp / performance tape.
Yeah the hairspray thing… apparently it needs to be a very specific brand of hairspray which isn’t available here in South Africa. I have tried the ones that are available and none of them work. Plus the hairspray option is expensive. I can get 5 litres of acetone for about R100 (approx $9) and that last about a year. I make about 100ml slurry at a time in a jar. This takes a few minutes, then I apply it to the glass with a brush before the print starts. Not exactly work… YMMV.
I have 3mm mirror glass with hairspray and it works well. I don’t use clips, but little corner pieces that attach to the heatbed posts underneath. I modified them so that they come out level with the print surface of the mirror.
As far as printing with PLA, I imagine if you heat it even just a little bit (50 deg C), then put the mirror/glass in the refridgerator/freezer, the parts will pop off fairly easily.
If that doesn’t work, a razor blade should be able to get the part off with little to no damage to the part.
I’ve was using a regular plate glass from Lowes. It’s only 1/8 thick. It worked great but I wanted something a little thicker. Currently I’m testing a 1/4" thick mirror that I had in the garage. I cut a 8x10 panel because I wanted more clearance between the clamps and the extruders. Printed 4 abs corner mounts that I found on Thingiverse. It’s been working pretty well. I cut extra panels so I can prepare the plates on my workbench then swap them out as I need them. Hairspray and glue sticks have worked best for me. One thing to remember before adding glass to your heat bed is to print a spacer for the z axis limit switch. It is needed to adjust for the glass thickness. If you mount your glass without it your extruders will crash into the the glass plate. Look on Thingiverse you will see what I’m talking about.
Tried simple float glass ( windows, photo frame etc ). All worked well for a while then I had one particularly well-adhered print and I actually ripped shards out of the surface of the glass when I popped it off. Bit worrying but good 'n cheap.
Found a supplier of borosilicate - They use it for solid fuel stove windows - Chiswell fireplaces, St. Albans. Expensive - £15 each for 130mm x 140mm. Works really well, especially with Pritt / UHU Purple stuff but I did come into the workshop one day and the plate had split in half! A case of too much adherence, me thinks. Didn’t stop me. Now use B’silicate almost exclusively but right now, the plates have BuildTak on them - Maaan! That stuff is awesome! maybe you should give that a go. No lines!
I have the newer model of FFCP with the thick aluminum build plate. It should still be exactly the same if you have the one with the thin aluminum plate.
I am using 3/16 standard glass from a local glass shop. Works great haven’t had any warped but I did break a few… it was my fault as I dropped them too hard on the counter (my hands go numb too many back surgeries (15))
I am using some corners from thingiverse that I believe makersome designed, however I made my own change for the thicker glass. If you need the corners let me know and Ill send you my stl files. I printed them out of ABS, glass is non borosilicate, but still works.
I am planning up upgrading the size of the bed to larger glass for larger print volume and will be playing with some polycarbonate and maybe some mirror as well.
Also, yes borosilicate glass is VERY good glass and recommended, however, I just spoke to my glass shop davis glass in las vegas, they use tempered glass, and they even use them on fireplaces where there is flames involved not directly but temps should get up to 100 - 200C. They say it works great. I too have been printing in ABS a lot and other filaments like polycarbonate and bed up as high as 120. No problems there.
I did go to frys and bought a tube of MGChemicals white lithium grease (yeah I know not really on this subject but related) and added to the Z screw and bearings, and also got some silicone heat transfer paste. Both came in a tube like toothpaste and the heat transfer # 860-150G was around 16.50 USD, and the white lithium grease #8461-85ML was 7.99 USD. I noticed the bed heats up a little faster and holds a more stable temp as well. I would like if I could find a way to easily clean the glass and re apply hair spray to put some paste on the glass to the aluminum plate too. I just haven’t had any issues with 1st layer adhesion to have to try it lol.
Anyhow I hope my 2 cents maybe 3 cents is worth something to someone!
I did, and dude: no adhesion problem since then ! I mostly use PLA in my FFCP, and use hairspray (strong hairspray). Works wonders to adhere several prints in a row.
If I need traditional strength (maybe because a big part has only little contact surface with the build plate), then I use gluestick, and the problem is gone.
Just beware that my laser thermometer registers only a glass temperature comprised between 65 and 68 degrees when I ask for a build plate at 70 degrees, sot there’s a small temperature drop.
The most challenging part of the glass mod is to offset the home of the Z axis by putting a bit of plastic inf front of the home Z interrupter and to correctly fasten the glass on the bed so it does not slide during the printing.
