I have since emailed Mikey at Wanhao. He kindly sent me a HEX version of the V1.3(B) firmware, which will load though Cura >Machine>Install Custom Firmware. The only problem is: my Board appears to have an older version of EEPROM, so the printer, which was working apart from a temperature readout offset of +43 degrees, is now not working at all. I have no recovery from this unless Mikey sends me a compatible (older?) HEX file.
I too am thinking about swapping out for a RAMPS 1.4 + LCD Display, which is considerably cheaper than a replacement Wanhao board. I would prefer not to do this, as the space requirements are much greater, and will undoubtedly require some sort of external casework.
I hope to obtain all the required settings for Ramps 1.4 Marlin Configuration.h, in the i3mini.rar Configuration.h file
Cura option to ‘Install Default Firmware’ is greyed out, which is a shame, as this would be the best option. I was disappointed not to find this on the supplied SD card.
I recompiled the firmware that was published but can not get past 130X 155Y 110 Z
just want to check if the enhanced bed firmware you have would work at all
You are both lucky if you are getting more than 150mm. Mine I get X115, Y135, Z100. Travel is limited physically, I will need a mod to make it any bigger.
Suspected the file supplied by Mikey is an older revision of the firmware 1.1.4 and for sure not the same settings as the OEM. Getting a hold of Power Spec is harder than reaching Wanhao.
I only got this printer a week ago, and have yet to confirm actual travel, but HEX file works. This is the file name i3mini-wanhao-130X160X130.hex
Cannot comment on firmware version, but Standard firmware file name supplied by Mikey, at the same time, is i3mini-wanhao-v1.3.hex
With regard to contacting Wanhao: I have found them to be really good, with quick response times, and good answers. Just have to allow for time difference.
as can be see way back at the start, 1.3 is the ONLY thing that Wanhao has offered, amd have seen all flavors of it but not installed as I suspect they are older versions of Marlin.
Mine is 1.1.4 as from Powerspec. Though it clearly states this one is a Wanhao i3 Mini. (details in OP).
I would like to update to 1.1.8, but lack the specific configuration.h data, and a few other tweaks for the Mini. If I can round this up, I will make it available so that every one has the ability to generate updates for their machine as needed.
Manualy sending code M501, then M503, should result in a fairly solid regurgitation of just about everything the PCB is able to tell you.
Sample provided for putput. Do not try to use codes that are listed as output less you are ready for bad thinsg to happen or know how to use all of these codes. Please only use M501 and M503 to grab a data dump. M303, Numbers generated if your firmware supports the function, are to added to the Configuration file. Do not use if you are not looking to re-calibrate your heater data.
I have flashed hex that was provided from Mikey, and all is good BUT im missing option to level bed, andyone know solution? or how to accesses it? since on my printer now its MIA
I remember there being a flag in the files to turn that option on and off but i do not recall where. For the time being, if you run Simplify 3D they have a function built in that does much the same thing as it just moves the head to each corner and Z=0. You still have to turn the screw until it is set right. You should also be able to use a control panel to either send hand written code to tell the head where to go.
i just got .hex file from wanhao Mikey, as i know its complied and i cant change anything in it?, i wrote to him about this and he sent me original hex, but i want bigger print are those 20mm from Z means alot to me, guess ill have to use simplify 3d for leveling for now
I can put the hex on a google drive somewhere , or you can use the TH3 Unified firmware and compiel yourself and uplaod that one, that way you have 1.1.18 Marlin as well with all that comes with it.
