May 2015
Yes, I do print, but whether or not I will be able to do this successfully, I’m not sure. What material/colours do you need these in?
I’m just having a quick play with the file you sent me on my machine in white ABS, but it’s so small and delicate, at least in these dimensions that I’m not sure it is printable, at least using FFF methods. You might need something more specialised, or someone with better kit than me.
Can I ask what the application is? Is there room to manoeuvre on sizing etc? I’m just playing with a larger version now to see what happens.
Mike
I’ve attached a Jpeg to give you an idea of what I’m trying to achieve (the full model) - I’m making a much smaller prototype/exhibiton model. The seating part is around 45cm at its longest length across so the modules need to be ‘around’ the right size so there is bit of leeway.
how much bigger were you thinking?
Francesca
That would be brilliant if you could ! did you read the below comments about the correct scaling etc?
Message me if you need more detail/info on the project!
I will, sorry my internet is so slow it’s taking ages to download the file. Also by how much can I upscale the design?
George
Ok I will try one now at 2500% original scale which is slightly over 4.5cm3 but will give us an indication. My gut instinct is that the poles may need to be thicker. I’ll see though.
Ah thats a shame, I wouldn’t be able to make the pole thicknesses thicker quickly as it was a long process making the original model and I’m no expert in CAD! Thank you for the advice.
I suppose you could ask some people on here. There are some actual experts on here!
yes this one looks better, ill have a g at printing it tomorrow if you like.
Hi gabriela3D, unfortunatly i was the 1st person to let francesca down! i current have about 30-40hrs works cued up on my machine and was unable to get a new job going untill the end of the week!
I have tried it again and I do not believe this will be printable on a fdm machine like mine. I would see if there is anyone near you with a resin machine as others have stated. It may be able to be printed if it is much bigger than 45mm3. It is just too small for my machine. I don’t know anyone that has a resin machine and could have it done by Thursday, unfortunately.
Sorry I couldn’t help.
If this is the model I uploaded you may have to check with Francesca that it is the right model. All I did was upscale it though.
