May 2015
@jeri
Hi George,
Did you want to try that rotation? The new base is the only ‘triangle’ that is connected to the ‘square’.
I have G-code if you want it, or you can try my attached file.
That rotation is less demanding of support material, but of course, a lot of support material is still required.
I think that resin or powder based printing will be a lot more efficient, but I’m not sure that Francesca has the luxury of time to find or get those printed.
As you’re much closer, would you still be able to fulfill this?
If not, let me know. I could just about print these in time, in ABS anyway, if needed. .35mm nozzle, ‘fine’ print is the best I can do though… Some retouching/rework might be needed…
Mike
Module - thickerMC.stl (2.21 MB)
I tell you what I’ll do I’ll try a low quality on with lots of added supports and tell you if it goes well or not. Also I think that a powder or resin would be better suited but there’s none round here that can do it fast enough I had a look through some hubs.
@frankiecheska
Hi Francesca,
OK cool. I’m just trying a new trial print at the moment, but see my reply to George…
If you can get a resin, or powder based print in time, I’m sure that that would be the way to go, but if not, someone here might be able to try that alternate orientation, which is just a little bit more forgiving on a filament (FDM/FFF) printer.
If your deadline is strict, and no-one else can do it, I should be able to print 15 units for you in time for Thursday, if white ABS (see materials guide here - Online 3D Printing Service | Instant 3D Printing Quotes | Hubs) would work for you. Some hand rework might be needed on these prints to get them to an sufficiently acceptable standard for you.
I hope this helps!
Mike
