I will, sorry my internet is so slow it’s taking ages to download the file. Also by how much can I upscale the design?
George
Anything that fits into 45mm3 is fine !
Francesca
Ok I will try one now at 2500% original scale which is slightly over 4.5cm3 but will give us an indication. My gut instinct is that the poles may need to be thicker. I’ll see though.
okay, there is leeway with the pole thickness also if that helps.
Ah thats a shame, I wouldn’t be able to make the pole thicknesses thicker quickly as it was a long process making the original model and I’m no expert in CAD! Thank you for the advice.
I suppose you could ask some people on here. There are some actual experts on here!
I’ve tried a much simpler CAD version - would this work??
Module - thicker.stl (14.3 MB)
yes this one looks better, ill have a g at printing it tomorrow if you like.
Yes thank you, that would be brilliant.
Hi gabriela3D, unfortunatly i was the 1st person to let francesca down! i current have about 30-40hrs works cued up on my machine and was unable to get a new job going untill the end of the week!
I have tried it again and I do not believe this will be printable on a fdm machine like mine. I would see if there is anyone near you with a resin machine as others have stated. It may be able to be printed if it is much bigger than 45mm3. It is just too small for my machine. I don’t know anyone that has a resin machine and could have it done by Thursday, unfortunately.
Sorry I couldn’t help.
These models should be to the scale of 45mm3 if that helps at all.
module to print 45mm3.stl (17.1 MB)
Module - thicker 45mm3.stl (12.2 MB)
