Ah okay ! thank you!
Ah thats a shame, I wouldn’t be able to make the pole thicknesses thicker quickly as it was a long process making the original model and I’m no expert in CAD! Thank you for the advice.
I suppose you could ask some people on here. There are some actual experts on here!
I’ve tried a much simpler CAD version - would this work??
Module - thicker.stl (14.3 MB)
@jeri
yes this one looks better, ill have a g at printing it tomorrow if you like.
Yes thank you, that would be brilliant.
Hi gabriela3D, unfortunatly i was the 1st person to let francesca down! i current have about 30-40hrs works cued up on my machine and was unable to get a new job going untill the end of the week!
I have tried it again and I do not believe this will be printable on a fdm machine like mine. I would see if there is anyone near you with a resin machine as others have stated. It may be able to be printed if it is much bigger than 45mm3. It is just too small for my machine. I don’t know anyone that has a resin machine and could have it done by Thursday, unfortunately.
Sorry I couldn’t help.
These models should be to the scale of 45mm3 if that helps at all.
module to print 45mm3.stl (17.1 MB)
Module - thicker 45mm3.stl (12.2 MB)
@frankiecheska
@jeri
Hi Francesca,
Working with your thicker framed model, and maxed to fit in a 45mm3 area, I found a new orientation that might just make it possible to print on an FDM printer. Could you have a look at the image and see if that would work for you?
Mike
If this is the model I uploaded you may have to check with Francesca that it is the right model. All I did was upscale it though.
Hey, that looks fine to me !
I’ve had a play around with adding supports aswell and I got this in the end. Although it would need a lot of clean up, it would print.
@jeri
Hi George,
Did you want to try that rotation? The new base is the only ‘triangle’ that is connected to the ‘square’.
I have G-code if you want it, or you can try my attached file.
That rotation is less demanding of support material, but of course, a lot of support material is still required.
I think that resin or powder based printing will be a lot more efficient, but I’m not sure that Francesca has the luxury of time to find or get those printed.
As you’re much closer, would you still be able to fulfill this?
If not, let me know. I could just about print these in time, in ABS anyway, if needed. .35mm nozzle, ‘fine’ print is the best I can do though… Some retouching/rework might be needed…
Mike
Module - thickerMC.stl (2.21 MB)
Brilliant ! Have you tested it?
