May 2015
Ah thats a shame, I wouldn’t be able to make the pole thicknesses thicker quickly as it was a long process making the original model and I’m no expert in CAD! Thank you for the advice.
I suppose you could ask some people on here. There are some actual experts on here!
yes this one looks better, ill have a g at printing it tomorrow if you like.
Hi gabriela3D, unfortunatly i was the 1st person to let francesca down! i current have about 30-40hrs works cued up on my machine and was unable to get a new job going untill the end of the week!
I have tried it again and I do not believe this will be printable on a fdm machine like mine. I would see if there is anyone near you with a resin machine as others have stated. It may be able to be printed if it is much bigger than 45mm3. It is just too small for my machine. I don’t know anyone that has a resin machine and could have it done by Thursday, unfortunately.
Sorry I couldn’t help.
If this is the model I uploaded you may have to check with Francesca that it is the right model. All I did was upscale it though.
@jeri
Hi George,
Did you want to try that rotation? The new base is the only ‘triangle’ that is connected to the ‘square’.
I have G-code if you want it, or you can try my attached file.
That rotation is less demanding of support material, but of course, a lot of support material is still required.
I think that resin or powder based printing will be a lot more efficient, but I’m not sure that Francesca has the luxury of time to find or get those printed.
As you’re much closer, would you still be able to fulfill this?
If not, let me know. I could just about print these in time, in ABS anyway, if needed. .35mm nozzle, ‘fine’ print is the best I can do though… Some retouching/rework might be needed…
Mike
Module - thickerMC.stl (2.21 MB)
I tell you what I’ll do I’ll try a low quality on with lots of added supports and tell you if it goes well or not. Also I think that a powder or resin would be better suited but there’s none round here that can do it fast enough I had a look through some hubs.
@frankiecheska
Hi Francesca,
OK cool. I’m just trying a new trial print at the moment, but see my reply to George…
If you can get a resin, or powder based print in time, I’m sure that that would be the way to go, but if not, someone here might be able to try that alternate orientation, which is just a little bit more forgiving on a filament (FDM/FFF) printer.
If your deadline is strict, and no-one else can do it, I should be able to print 15 units for you in time for Thursday, if white ABS (see materials guide here - Online 3D Printing Service | Instant 3D Printing Quotes | Hubs) would work for you. Some hand rework might be needed on these prints to get them to an sufficiently acceptable standard for you.
I hope this helps!
Mike
Actually Mike you can take it because I don’t whether it will defiantly work and I’ve got to get another print done for some else. Also it will probably turn out better on your machine. So you can take it buddy.
Hi Mike,
George has passed it to you as he has another order to complete,
Would you still be able to do this? / deliver before thursday?
Im fine with the material and a bit of handwork.
Let me know !
Francesca
Thanks George! I’ll have a look!
Actually, just discussing with Francesca offline, I think I might have found a new way of printing this… The symmetry eluded me at first! Will let you know how I get on!
Thanks again my friend!
Mike
