Apr 2017
=I have found someone to help with this. Thank you all for your help.=
Been looking around for a while, trying to find some help with a prop for my cosplay, but keep running into dead shops or closed commissions… hopefully I’ll have some better luck here.
Im looking for a guitar commissioned as such:
https://s10.postimg.org/ry02c56k9/guitar\_1.png
https://s14.postimg.org/f7tmrv01d/guitar\_2.png
https://s12.postimg.org/7tn22i33x/guitar\_3.png
https://s4.postimg.org/y1apcs299/Guitar\_4.png
https://s16.postimg.org/7u5lp9ps5/guitar\_5.png
Piece is Shu zo’s guitar, from the anime “Show by Rock”.
If there is anyone here that is able/willing to do this, I would need the piece by mid-august at the latest. If anybody wants to toss me a quote, I’d appreciate that and I’ll get back to you asap.
Thank you, kindly.1
    Apr '17
    Jan '18
  • 31
  • 3.9k
  • 13
Very neat looking guitar ? What are the dimensions of it? I 3d modeled and printed a hera syndulla blaster, which is on Thingiverse, but my 3d printer only has 8"x8"x7" print area. I’m going to have to watch Show by Rock now.
Hi Jikosky,
I might be able to help you out. I’m good with doing cosplay commissions. Just a couple questions though:
-Does the guitar have to actually function or is just just for display?
-Are you ok with it being made in PLA plastic?
You can check out some of the stuff I’ve done at my website: millersmaddesigns.com 3
Thanks,
-Michael
I may be able to help you, as I make costumes and props for a living. Just wondering where you’re based so I can take postage prices into consideration when giving a quote :slight_smile:
I could make this for you. Design and print. Did you want it as an actual guitar or just a prop?
This can certainly be done, however if this is to be a functional guitar I would suggest having the main body milled from hard wood. This due to the stress and tension from the strings. People don’t realize just how much force six thightend steel strings can exert on the body and neck of a guitar. This is why you’ll find a steel rod down the shaft. If this were printed in plastic I suspect immediate failure. The accents however could be 3D printed.
Hi, as a guitarist I think this looks a pretty cool project,
I’d be more than happy to take a look at quoting for you.
If you’d like to contact me to discuss details, I’d be happy to offer you a number of options.
Thanks
Dave
Heres more pictures The Kuudere 3
Id say fully 3d printing this would be expensive and an overkill. Foam would be better and lighter. Looks like a rounded piece of wood was used along with cardboard.
Hey all, I want to thank everyone for such quick replies. Just want to say quick Im in class currently and for the majority of the day but I will go through and get back to you guys once labs let out. Some quick notes I didn’t mention that were brought up: -I’d prefer the piece to be functional, but it’s not something that is a must as long as it appears to function. This is a cosplay piece first, so my priority is making sure it meets those guidelines for conventions. As far as dimentions, refer to keebie81s link for more photos that should help with the guitars dimentions/layers. I’ll be in contact later tonight. I appreciate your alls time. Thank you.
I do a lot of prop work, mainly with the 501st Stormtrooper guys. Are you looking for the entire thing assembled and finished or just the parts 3d printed? Do you have the 3D model files already available or will you need someone to model them up for you? If you’re needing this modeled from scratch, things do start to get expensive.
Give me relative size. Your location. If you want the clock functional. I can design it and use both 3d printed and laser cutter parts to make it.
Looks interesting. I might’ve willing to give it a go.
My estimate is 200 plus cost of supplies and design. Design 30, supplies be about 30. And shipping. So this prob can be around 300.
I have a couple of questions:
Do you require the neck to be printed and if so what is the length?
What is the diameter of the larger circular piece?
Yes, the entire thing would need to be made. From what I understand, the guitar would not be functional if fully cast as a 3d print unless somebody (yourself or others) are able to make the neck be able to withstand the torque of the strings, which would be preferred, I am alright with it simply being a prop if it is not possible.
As far as the length and diameter, I don’t have exacts, but I’m sure if I spent some time analyzing the photos and comparing them to myself (5’8’’/173cm), I could come up with a guesstimate.
I know its kinda vague answer, but at the moment, thats about the best I can answer. I’m sorry ;–;
Thank you for finding the rest of the images. While, yes, it might be overkill, I am also looking for durability and quality. I have some foam props (Elks staff from .hack//infection is my major piece), but they’re fragile and tend to crack or chip, which is why I’m looking to invest a little extra for a higher quality prop.
Hi, and thank you for your reply. You have some fantastic pieces, very nice work!
To answer your questions, the guitar doesn’t need to be functional, but if its possible, it would be a huge plus for the cosplay.
As far as the plastic goes, I wouldn’t have an issue. I know this poses a bit of a challenge for the functionality of the guitar, but in the end, it is a prop for a cosplay vs a real instrument.
Some more images of the dimensions and such are below:
phariam: “ Show By Rock!! - Shu☆Zo’s Guitar ”
Thank you much!
Hi, and thank you for your reply!
I am unaware of the exact dimensions of it, but here are a few more images to get a better feel for it.
Show by rock kinda threw me for a curveball as far as animes go. I wasn’t expecting it to be that great, but I quite enjoyed it. Hope you do as well! :slight_smile:
Sounds like you’re in the initial stages of this project. Printing will come, and quickly, after the long journey of researching the physics of stringed instruments, and design costs. When you get to the printing stage, find a hub that offers large build volumes, to accommodate the single piece design.
best of luck
Hi and thank you for your reply!
If it could be made into a reliable, functional guitar, thats a huge bonus for the cosplay, which I’d be willing to go for, but the main focus is a prop.
I agree that the torque of the strings on the neck would cause would be high. If there is a way of making this functional, I’m down for exploring those routes, as it would make the prop (and therefore the cosplay) more realistic, but my main focus is the prop itself; functionality is nice, but secondary. :slight_smile:
I greatly appreciate you being a guitarist, and therefore, your knowledge on both these two subjects. My question thusly is that I understand that making this a functional piece will be difficult, so what would your thoughts be on the best way to design this so the prop comes out as intended (top priority), yet still a functional piece? As mentioned below, and as I’m sure you know, the strings will cause a lot of stress on the neck for a functioning piece; would you reinforce the neck or are there better options available? Thank you much :slight_smile:
Yes, the entire thing would need to be assembled.
No, I dont have any files, just the images posted above.
I understand the costs of labor/time/etc as far as these things go, which is why i’m not terribly concerned with a budget, within reason, of course. :slight_smile:
–As far as a relative size, I’m 5’8’’/173cm, so a full-sized guitar would probably be best.
–The clock would be pretty sweet if functional, and would give the prop some use when not cosplaying, but is a low priority. Still… that is a pretty cool idea and will have to give that some thought.
Thanks much! :slight_smile:
My original plan was wood or a combination, which should have made this a bit easier of a build as a functional piece, but I just couldn’t find anybody willing to commission it, which is why i’m moving to what, in my opinion, would be my next best option.
Im not very knowledgeable in 3d printing as all my props are done with foams and pvc. I’ve also never had needed a prop that, in theory, can be used as an instrument, so you’re right there: I have no idea about stringed instrument physics :stuck_out_tongue:
I’d suggest using an old guitar as a base, so you have the reinforcement in the neck already built in. You cold then 3d print all the add on items. It would then be much easier to make this a functioning piece, and would be much more durable. You are likely to loose some functionality due to all the add-ons though. Would you be looking for the piece to be styled exactly on the one in the pictures, or would you be looking for something closer to the one in the artwork I’ve seen?
After going back to look at both, i noticed there are differences between the two in the anime and the one in the photo. after comparing them and taking things into consideration, the one I’m interested in would be the anime 3d rendering of the guitar. [I will edit the original post to reflect this as well as post links to the screencaps of the model.] I attempted to get multiple screen caps to get better angles/outlines of certain features. I hope this helps.
It could be designed to facilitate a tensioning rod, however, I’m reminded of those cheap $50 ukuleles…they don’t have rods and still work.
depending on your level of interest, actually building it from wood would be a pretty intimate project and would glean all the information you’ll get after working with a designer (which will be expensive). The collateral benefits to building, if well documented, could be huge also.
There are a number of approaches to this idea. How close to it do you want to get?
Thanks for the new pictures. Looking at these, I’d say that the guitar lends itself more towards a prop rather than a working guitar.
The full clock face body, would not give you access to the strings, without having the face detachable you would be unable to play it, I think this would make the piece loose some impact. I would be inclined to focus on making the clock and cogs work.
I’d still use a guitar neck as a base so you can give the impression of having tuned strings.
If your happy with the proposal I can draw up some sketches and get you a detailed quote.
I’d be shipping from the UK so will include the cost of a hard flight case to protect the piece during shipping.
9 months later
