Hey guys, how do you put a glass bed on the flashforge creator pro? Do we put the glass on top of the build platform that came with it? What if that is warped how do you level the glass then? Please help. Thanks.
Hi @Johnnyo1012 I fitted a glass bed to my Pro after only a couple of weeks as I was unhappy with the blue “mat” that comes with the machine. I removed the mat and put the glass directly onto the build platform. I tried using corner brackets to hold it in place but they didn’t work well for me so I’ve always just used Kapton tape at the edges, it sounds like a fudge fix but it holds the glass really well and doesn’t get in the way. A while after fitting the glass I was having problems with adhesion so fitted a PEI sheet to the glass and it’s been that way ever since.
Don’t forget you’ll need a shim under your z-stop to account for the extra thickness of the glass.
@cobnut what if the build platform is slightly warped? I am trying to level the nozzles in the center of the bed and once I get it perfect in the center I go to level the sides. After I level the sides I go back to the center and the nozzles hit the bed. That is why I think it is warped. If I put glass directly on top of it won’t it affect the glass? Also where did you buy your glass? Thanks.
Hi @Johnnyo1012 are you adjusting more than one screw at once? I found when I first got my Pro that you need to adjust at least two of the screws at once when levelling the bed, if you turn just one it tends overly adjust the other points. When levelling, if I need to be adjusting the front screw I’ll usually adjust the two back screws by half a turn to every full turn of the front screw and so on. Sometimes I go through the levelling process more than once.
I think it’s unlikely that the bed itself is physically (and permanently) warped, it’s more likely just a levelling issue. If it is warped you really need to replace it.
My glass actually came with the printer when I bought it, it was a bundled package.
Probably around 3-5 mm. Type of glass will make a difference though. If you are only going to print PLA or other materials that won’t require a bed then any glass should do. Otherwise most tempered glass will work up to 80C. Anything higher than 80C for a heated bed I would recommend going with Borosilicate.
You may want to just start out by taping the glass to the bed. I used blue painters tape for a while because I got frustrated with "corners’ that didn’t work well. Main thing is simply for the glass to not move during printing. Some people use those bulldog clips but just make sure to position them so the nozzles won’t hit them!
