Sep 2017
We use 3mm boro glass from ebay and just scale the shims z height to match. Again this is the least effort or fast method not necessarily the cheapest or best for everyone.
Is using bull dog clips to hold the glass on a good way? I think it’s the easiest, fastest, and easiest way to remove if needed. Let me know your thoughts. Thanks.
Yes, it works fine. Just watch the placement of the clips and move the extruder around to check for interference.
For instance, if you put a clip on each side and are printing a small cube in the middle of the plate then most likely the clips will be out of the way.
Yes, you can, you can refer some guide video on Youtube. There are some videos about “How to Upgrade glass bed for Flashforge Creator”
rolling sky 30
