HI, we meet a problem with our printer. (Delta WASP on 2040 turbo)
At the time of the manual leveling, the extrudeur comes to position wich is too low and knocks on the print plate even if the plate is in the lowest position!
The problem seems to be the origin position in Z of the extrudeur.
What are the good values of regulations factories and how to repair this problem?
Thank you very much
Try to discover if it’s a stepper problem, in order to do that, click “auto home” and then “move axis” “1mm” “z axis” and manualy check if the extruder go down 400 stepps.
Hi Alessandro, unfortunately i can’t even set the space between the nozzle and bed since even at the beds lowest position there is 0 space in between; which makes manual leveling impossible. Any ideas ? some kind of “factory reset/ settings” we could align on in case we messed up changing values somehow ?
Thanks but i did already check that. Manual leveling is impossible since the bed at it lowest point is still so much in contact with the nozzle we can’t even fit a paper sheet in between. Might be some problem with the initial position of the nozzle ?
Yes make sure your Z Height is set to 442. Or restore the machine to its default settings. Sometimes people accidentally alter/tweak certain “advanced settings.”
make a “autohome” on the display you will see the measure of Z as 441 or 442 then go to “prepare-height change” and decreases the value z. then go to “advanced” and click “save in EEPROM”
do not touch diagonal and radius. Take a sheet of A4 paper and adjusts the three 1,2,3 points outside so that the foil does not touch. then controls the center point 0. it could be that the point 0 is lowest. No problem print a file and see if it works.
Ok for the manuel leveling with a sheet of paper, and the center point being the lowest still. But i still want to know if the values are correct and if not what are those ? Because i’m pretty sure we did alter them by mistake in “advanced settings.” (especially the Radius one)
