HI, we meet a problem with our printer. (Delta WASP on 2040 turbo)
At the time of the manual leveling, the extrudeur comes to position wich is too low and knocks on the print plate even if the plate is in the lowest position!
The problem seems to be the origin position in Z of the extrudeur.
What are the good values of regulations factories and how to repair this problem?
Thank you very much
Try to discover if it’s a stepper problem, in order to do that, click “auto home” and then “move axis” “1mm” “z axis” and manualy check if the extruder go down 400 stepps.
do not touch diagonal and radius. Take a sheet of A4 paper and adjusts the three 1,2,3 points outside so that the foil does not touch. then controls the center point 0. it could be that the point 0 is lowest. No problem print a file and see if it works.
Ok for the manuel leveling with a sheet of paper, and the center point being the lowest still. But i still want to know if the values are correct and if not what are those ? Because i’m pretty sure we did alter them by mistake in “advanced settings.” (especially the Radius one)
