Mar 2016
HI, we meet a problem with our printer. (Delta WASP on 2040 turbo)
At the time of the manual leveling, the extrudeur comes to position wich is too low and knocks on the print plate even if the plate is in the lowest position!
The problem seems to be the origin position in Z of the extrudeur.
What are the good values of regulations factories and how to repair this problem?
Thank you very much
Joël D
Try to discover if it’s a stepper problem, in order to do that, click “auto home” and then “move axis” “1mm” “z axis” and manualy check if the extruder go down 400 stepps.
Hi ,we change the Z value to 442,it is better,but now we got an other problem,the 0 point during the bedleveling opération,is
lower than the other 3 points (1.2.3).
Is it a problem of bad values of radius and diagonal rod.We got for radius 175.6 and for diagonal rod 294.
Thanks to all, for your precious help. Problem solved , it was an unfortunate values changes in “advanced settings”
beside your messages i also received a mail from WASP Support which could turn out usefull for people having the same trouble :
"to change the distance between the extruder and the point zero,you have to decrease the ,zero, value changing
radius: 175,1
diagonal rod: 294,5
practically i change by 0.5mm the two values,i remove 0.5mm from radius and i increase the diagonal rod value with the same value (0.5)
Usualy you can start from 0.3mm and reach 1.0mm like maximum value to find the right leveling values .
After you change the radius and diagonal rod values you have to store memory(advanced-store memory)"
After testing, turns out our values are :
Z Max : 442
Radius : 174.6
Diagonal Rod : 295.0
Thanks again to you all ! Let’s Print !
