Sep 2016
Basically the title.
Trying to make a CNC machine for fun as my first project.
I am 3d printing the guide that has to slide on 8mm shaft. I have 2 options:
1) Make a 3d printed part with 8mm hole and hope that it will slide easily on aluminium shaft.
2) Make a 3d printed part with 15mm hole, and put metallic bushing bearings in it, to make sure 8mm slides easily through.
Which option makes more sense?
Thanks! (my first post on the forums, sorry if something wrong)
    Sep '16
    Sep '16
  • 14
  • 3.1k
  • 11
This would work well until the chrome started wearing as aluminum is a very soft metal and bearings are very hard it would start scoring very at minimum I would use tool steel
You can do #2 obviously. Create a 3D part with clearance for a LM8UU bearing.
However, if it was me, I’d first try to print off one of the igus bearing designs from thingiverse and see if it’s smooth enough for the application.
aluminium is a horrible choice for a cnc machines linear guide shafts, unless you are planing to never mill hard materials like, wood, plastic and metals.
printing the linear bearing is also a bad idea, tolerance need to be tight and you want it to slide smoothly without the “stick and slip” effect else your servo or stepper motor has to waste extra torque just on movement alone.
the second option makes more sense, and get a good quality shaft which is suited for the job.
yeah I figured I fucked up with choosing aluminium… it was just to easy to obtain. In my case, CNC will not be milling stuff, it’s more of a pen plotter really. I’ll attach a pan to it, it will draw on a paper, that’s all. I wonder when aluminium will wear off though, how long will it take.
Yeah my bad… going with aluminium was stupid. I’ll get steel ones, they are just harder to get, I did not want to use amazon for that, as it was very expensive for some reason. How long will it take till aluminium wars off btw?
You can use the special bushing Filament from IGUS
Hi Avetis
The second option I think is good,the metallic bushing bearings a perfect fit.
