Sep 2016
You can use the special bushing Filament from IGUS
I came across these 3d printed bearings with PTFE liner on thingiverse the other day, I’ve not tried them but they might suit your needs.
Kind regards
Tom
That’s pretty neat! and should be the cheapest option. I wonder where he get’s PTFE with 2mm OD, all I found on ebay was 3mm minimum.
Here’s what is important in my opinion…
It is good design, for a sleeve-type bearing setup, for the bearing to be softer than the slide/rail/shaft. This way, the bearing wears out before the shaft. This would be the case for either of your options, but I presume option number two would lend itself to a quick swap of a sleeve should the bearing wear out. So, I think option #2 is good.
Also, as for material, aluminum isn’t necessarily bad if it is appropriately sized for the intended use. You do not want to run ball bearings against aluminum, no, but for a sleeve type bearing application, plated aluminum is fine. Chrome is good, anodize would also be good. The plating protects against oxidization and provides a hard surface to resist abrasive wear.
Hopefully this helps you with your project.
Paul
Hi Avetis
The second option I think is good,the metallic bushing bearings a perfect fit.
