I am trying to print this thin wall object vertically from print bed. As you can see from the image it has a bulging part. This happens halfway midprint. My settings are as follows. By the way I do not have any first layer warping issues with this one, only problem is the bulging or bowing part.
Material : ESUN ABS+
Extruder Temp : 225C
HBP Temp : 110C
Speed : 60 mms
Tried Turning on a fan in front of it, and it just cracked. So I need your help guys, please. Thanks is advance.
I don’t typically print in ABS but you usually don’t want to cool ABS while printing. You want keep that environment as warm as possible and let it cool over time. Do you have an enclosure on your machine or is it in open air?
Its a rough sketch… Make them as wide as your nozzle diameter, and line them up so they are easy to cut with a razor blade. Since it a relatively straight edge, It should be easy to cut… I prefer flush cut PCB pliers over a razor blade.
Oh and… measure your grooves at the top, middle and bottom to confirm if that is the issue.
If your print settings are as i suspect the solution is simple, I print thin wall stuff all the time down to 0.8 mm, your print settings should be no finer than 0.2 layer height and set the print speed to a fast setting usually the problem is too much heat build up in the print
It’s extremely hard to get your chamber “too hot” for ABS. Stratasys FDM machines turn out excellent prints with ABS and have their chamber temperatures set at 70C to 90C; indeed, the fact that it can heat the chamber to those temperatures are a major part of the reason that they’re able to do so well.
As someone else has already said, it may not be avoidable given the current state of consumer machines. I would try adjusting both the extruder and the bed temperature, but which way I can’t tell you; just try to find whatever works best for you.
