Dec 2015
Hi guys, some print jobs on my i3 randonly stop mid print. Some jobs start ok but some jobs say printing and without any movement they turn idle, but other jobs work and complete perfectly. I use Simplify3D to setup for the i3 and think that may be the issue as it doesn’t seem like anything is wrong with the hardware (doesn’t overheat and full movement range is available and works). If I change the job (so put 3 up instead of 4 or 2 instead of 1 for example) it can fix the issue.
If I drag the gcode back into Simplify it displays as a complete job but just doesn’t do it. Could it be missing a line of code out or something?
It might be possible that you’ve selected one or more processes after clicking ‘prepare for print’. At the popup you can select which layers needs to be printed with a specific process…
Could it have to do with your energie saving computer turned on?
Try saving to a sd card and running it. For whatever reason I occasionally have issues with direct USB transfer.
and you can try ‘reset all settings’ under help… just to make sure…
and if you can’t figure it out get in touch with support from simplify… they’ve helped my out several times…
Same issue here as well. After talking with tech support it seems the only workaround is printing from SD card.
Frustrating since paying out $140 for a piece of software that functions as well as other free software. Feeling a sense loyalty to my REPRAP community, I wanted to support a company that grew from there. However, the lack of support on this issue is giving me little confidence in Simplify 3D as solid, reliable software. Come on Simplify guys - get your act together and fix your software.
JD
In all fairness: I simply love simplify3D because of all the options it has got. And I have never had ‘no problems’ when printing over USB with software like replicatorG, Makerware or Cura…So, to me it’s more like a spooler issue (and not a simplify3D). When the computer is really busy it will have a hickup on your print. But it would be great to have it fixed in general but meanwhile i’ve grown accustomed to using SD card for long prints and only use USB for the easy ones…
I’m not so sure it is the software. Could very well be the buffer on the com bus on the controller for your printer. I shielded every line I could get to and can now have 8 hour prints on a duplicator 4S over USB. YMMV…
I also had to go over each and every usb hub to make sure power saving was off… Some screen savers, etc on PCs can cause things to get flakey. Lots of extra RAM doesn’t hurt. I’ve had S3D take a few gigs before on some really high count models…
